muerte
| DS1307 & PIC16F877A problem... |
Posted: Thu Jun 12, 2008 4:05 am |
Please help me. I use driver from http://www.ccsinfo.com/forum/viewtopic.php?t=23255, my code:
#include "C:\CCS\SBC44B\T1\main.h"
#include "C:\CCS\SBC44B\T1\ds1307.c"
byte sec;
byte min;
byte hrs;
byte day;
byte month;
byte year;
byte dow;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
// TODO: USER CODE!!
ds1307_init();
ds1307_set_date_time(11,6,8,3,15,20,55);
ds1307_get_date(day,month,year,dow);
ds1307_get_time(hrs,min,sec);
printf("\f\%02d/\%02d/\%02d\r\n",day,month,year);
printf("\%02d:\%02d:\%02d", hrs,min,sec);
I send
11/06/08 15:20:55
and read incorrect
11/02/08 15:20:55
if send 11/09/08 15:20:55, read correct 11/09/08 .....
send 11/04/08 read incorrect 11/00/08...... why? Any idea? _________________ Best regards,
muerte |
Posted: Thu Jun 12, 2008 5:53 am |
In a string the backslash character ('\') indicates the next character is a special control character. Your code includes some illegal sequences. Change: | Code: | printf("\f\%02d/\%02d/\%02d\r\n",day,month,year);
printf("\%02d:\%02d:\%02d", hrs,min,sec); | to: | Code: | printf("\f%02d/%02d/%02d\r\n",day,month,year);
printf("%02d:%02d:%02d", hrs,min,sec);
What is your compiler version number? |
muerte
Posted: Thu Jun 12, 2008 8:38 am |
Thanks for answer, I change this line, but no effect.
Compiler : PCM Version 4.073. _________________ Best regards,
muerte |
Posted: Thu Jun 12, 2008 10:51 am |
Are you testing this program with real hardware, or are you using
a simulator such as Proteus ? |
muerte
Posted: Thu Jun 12, 2008 11:23 am |
Real hardware. Config on board: PIC16F877A@20MHz, DS1307, 24LC256, MCP23008, LCD2x16 + keypad (via i2c). I replace this RTC, no effect. Time ok, date wrong (send 11/06/08 read 11/02/08). No idea.... _________________ Best regards,
muerte |
Posted: Thu Jun 12, 2008 11:34 am |
1. Post the main.h file.
2. Are all of these i2c devices on the same bus ?
What is the value of the pull-up resistors ? |
muerte
Posted: Thu Jun 12, 2008 11:38 am |
Ok.
main.h
#include <16F877A.h>
#device *=16
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES PUT //Power Up Timer
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#use i2c(Master,Slow,sda=PIN_C4,scl=PIN_C3)
DS1307.C
//#define RTC_SDA PIN_C4
//#define RTC_SCL PIN_C3
//#use i2c(master, sda=RTC_SDA, scl=RTC_SCL)
//BYTE bin2bcd(BYTE binary_value);
//BYTE bcd2bin(BYTE bcd_value);
int8 bin2bcd(int8 binary_value)
int8 temp;
char retval;
temp = binary_value;
retval = 0;
// Get the tens digit by doing multiple subtraction
// of 10 from the binary value.
if(temp >= 10)
temp -= 10;
retval += 0x10;
else // Get the ones digit by adding the remainder.
retval += temp;
return(retval);
// Input range - 00 to 99.
char bcd2bin(char bcd_value)
char temp;
temp = bcd_value;
// Shifting upper digit right by 1 is same as multiplying by 8.
temp >>= 1;
// Isolate the bits for the upper digit.
temp &= 0x78;
// Now return: (Tens * 8) + (Tens * 2) + Ones
return(temp + (temp >> 2) + (bcd_value & 0x0f));
void ds1307_init(void)
BYTE seconds = 0;
i2c_start();
i2c_write(0xD0); // WR to RTC
i2c_write(0x00); // REG 0
i2c_start();
i2c_write(0xD1); // RD from RTC
seconds = bcd2bin(i2c_read(0)); // Read current "seconds" in DS1307
i2c_stop();
seconds &= 0x7F;
delay_us(3);
i2c_start();
i2c_write(bin2bcd(seconds)); // Start oscillator with current "seconds value
i2c_start();
i2c_write(0x07); // Control Register
i2c_write(0x80); // Disable squarewave output pin
i2c_stop();
void ds1307_set_date_time(BYTE day, int8 mth, BYTE year, BYTE dow, BYTE hr, BYTE min, BYTE sec)
sec &= 0x7F;
hr &= 0x3F;
i2c_start();
i2c_write(0xD0); // I2C write address
i2c_write(0x00); // Start at REG 0 - Seconds
i2c_write(bin2bcd(sec)); // REG 0
i2c_write(bin2bcd(min)); // REG 1
i2c_write(bin2bcd(hr)); // REG 2
i2c_write(bin2bcd(dow)); // REG 3
i2c_write(bin2bcd(day)); // REG 4
i2c_write(bin2bcd(mth)); // REG 5
i2c_write(bin2bcd(year)); // REG 6
i2c_write(0x80); // REG 7 - Disable squarewave output pin
i2c_stop();
void ds1307_set_time(byte hr, byte min, byte sec)
sec &= 0x7F;
hr &= 0x3F;
i2c_start();
//i2c_write(0x80); // REG 7 - Disable squarewave output pin
i2c_stop();
void ds1307_set_date(byte day, byte mth, byte year, byte dow)
i2c_start();
i2c_write(0x03); // Start at REG 0 - Seconds
i2c_stop();
void ds1307_get_date(BYTE &day, BYTE &mth, BYTE &year, BYTE &dow)
i2c_start();
i2c_write(0xD0);
i2c_write(0x03); // Start at REG 3 - Day of week
i2c_start();
i2c_write(0xD1);
dow = bcd2bin(i2c_read() & 0x7f); // REG 3
day = bcd2bin(i2c_read() & 0x3f); // REG 4
mth = bcd2bin(i2c_read() & 0x1f); // REG 5
year = bcd2bin(i2c_read(0)); // REG 6
i2c_stop();
void ds1307_get_time(BYTE &hr, BYTE &min, BYTE &sec)
i2c_start();
i2c_write(0xD0);
i2c_start();
i2c_write(0xD1);
sec = bcd2bin(i2c_read() & 0x7f);
min = bcd2bin(i2c_read() & 0x7f);
hr = bcd2bin(i2c_read(0) & 0x3f);
i2c_stop();
2. yes
3. 4k7 _________________ Best regards,
muerte |
Posted: Thu Jun 12, 2008 11:57 am |
Remove all the other i2c devices from the i2c bus, except for the LCD
and the ds1307. Then test it again. See if you still get the problem.
Remove these devices:
24LC256
MCP23008
keypad (via i2c).
Is the LCD using i2c ? Or is it using a normal parallel data bus ? |
muerte
Posted: Thu Jun 12, 2008 12:26 pm |
LCD and keypad using I2c.
I remove 23008 and... problem solved. Interesting.... 23008 and 1307 different I2C adress.
Thanks and sorry for my bad English  _________________ Best regards,
muerte |
Posted: Thu Jun 12, 2008 12:37 pm |
You could try to reduce the size of the pull-up resistors.
Change them to 2.2K or 1.8K. The minimum allowed pullup is 1.6K
for a 5v i2c bus.
Try the reduced pull-up value and see if it will work with the MCP23008
attached. |
