Write to 18F45K50 flash memory (SOLVED)
vtrx
PostPosted: Mon Sep 28, 2026 9:11 am     Reply with quote
I am trying to write to the flash memory of the 18F45K50 starting at address 0x4000, but the write operation isn't working.
I searched online but couldn't find the reason.
I ran a test using:
#include <18F45K50.h>
#FUSES INTRC_IO       // Usa o oscilador interno
#FUSES PLLEN          // Ativa o módulo PLL
#FUSES PLL3X          // Multiplicador do PLL em 3x (16MHz interno x 3 = 48MHz)
#FUSES NOCPUDIV       // CPU roda direto na frequência máxima (sem divisão)
#FUSES NOXINST, NOFCMEN, NOIESO
#FUSES PUT, NOBROWNOUT, NOWDT
#FUSES MCLR, NOLVP, SDOB3
#FUSES NOSTVREN, NODEBUG
#FUSES NOPROTECT, NOCPB, NOCPD, NOPBADEN
#FUSES NOWRT, NOWRTC, NOWRTB, NOWRTD,
#FUSES NOEBTR, NOEBTRB
#use delay(int, clock=48MHz, USB_FULL, act=USB)
#define FLASH_BLOCK_SIZE 64  // Tamanho exato do bloco para o PIC18F45K50
unsigned int8 data_aa[FLASH_BLOCK
void start_4000() {
    unsigned int32 addr;
    // Preenche o buffer RAM inteiramente com o valor 0xAA
    memset(data_aa, 0xAA, FLASH_BLOCK_SIZE);
    // Desativar interrupções é OBRIGATÓRIO. O ciclo de clock da Flash precisa ser exato.
    disable_interrupts(GLOBAL);
    // Varre de 0x4000 até o limite máximo da Flash (0x7FFF)
    for(addr = 0x4000; addr < 0x8000; addr += FLASH_BLOCK_SIZE) {
        // 1. Apaga o bloco de 64 bytes (Fisicamente transforma em 0xFF)
       // erase_program_memory(addr);
        // 2. Grava os 64 bytes com o valor 0xAA por cima do bloco apagado
        write_program_memory(addr, data_aa, FLASH_BLOCK_SIZE);
    // Reativa as interrupções após concluir todo o processo na Flash
   set_tris_a(0b00000001);   // RA0 como entrada
   setup_adc_ports(NO_ANALOGS);
   start_4000();
It didn't work.
PostPosted: Mon Sep 28, 2026 10:38 am     Reply with quote
What compiler version???
vtrx
PostPosted: Mon Sep 28, 2026 10:39 am     Reply with quote
5.115
From address 0x4000 onwards, the data becomes 00.
vtrx
PostPosted: Mon Sep 28, 2026 7:21 pm     Reply with quote
Upon analysis, the problem is likely the use of the PICkit 2 programmer with a `devicedat` file modified for the 18F45K50.
There must be an error in the fuse settings, as programming works perfectly if I use the 18F4550.
I’m going to buy another programmer.
PostPosted: Tue Sep 29, 2026 12:04 am     Reply with quote
Ah.
Thanks for coming back, I was starting to work my way through the
assembler generated, to see if there was anything obvious wrong. Very Happy
Eddy71ua
PostPosted: Fri Oct 02, 2026 12:22 am     Reply with quote
If you're working with the PICkit2 and PICkit3 programmers, I highly recommend checking out this software. It supports the new microcontrollers.
https://github.com/jaka-fi/PICkitminus
https://github.com/jaka-fi/PICkitminus/blob/master/PICkitminus_supported_devices.txt
vtrx
PostPosted: Wed Oct 07, 2026 4:52 pm     Reply with quote
Returning with the solution.
The problem was indeed the Pickit 2 with the modified DevFileDat.
I programmed it using the Pickit 3 and MPLAB, and the programming beyond address 0x4000 proceeded as expected.
PostPosted: Thu Oct 08, 2026 5:05 am     Reply with quote
Phew... Smile
Please edit the thread title, to include (Solved). Only you can do this,
and it helps to keep things nicely sorted.
