vtrx
| Write to 18F45K50 flash memory |
Posted: Mon Sep 28, 2026 9:11 am |
I am trying to write to the flash memory of the 18F45K50 starting at address 0x4000, but the write operation isn't working.
I searched online but couldn't find the reason.
I ran a test using:
| Code: | #include <18F45K50.h>
#FUSES INTRC_IO // Usa o oscilador interno
#FUSES PLLEN // Ativa o módulo PLL
#FUSES PLL3X // Multiplicador do PLL em 3x (16MHz interno x 3 = 48MHz)
#FUSES NOCPUDIV // CPU roda direto na frequência máxima (sem divisão)
#FUSES NOXINST, NOFCMEN, NOIESO
#FUSES PUT, NOBROWNOUT, NOWDT
#FUSES MCLR, NOLVP, SDOB3
#FUSES NOSTVREN, NODEBUG
#FUSES NOPROTECT, NOCPB, NOCPD, NOPBADEN
#FUSES NOWRT, NOWRTC, NOWRTB, NOWRTD,
#FUSES NOEBTR, NOEBTRB
#use delay(int, clock=48MHz, USB_FULL, act=USB)
#define FLASH_BLOCK_SIZE 64 // Tamanho exato do bloco para o PIC18F45K50
unsigned int8 data_aa[FLASH_BLOCK
void start_4000() {
unsigned int32 addr;
// Preenche o buffer RAM inteiramente com o valor 0xAA
memset(data_aa, 0xAA, FLASH_BLOCK_SIZE);
// Desativar interrupções é OBRIGATÓRIO. O ciclo de clock da Flash precisa ser exato.
disable_interrupts(GLOBAL);
// Varre de 0x4000 até o limite máximo da Flash (0x7FFF)
for(addr = 0x4000; addr < 0x8000; addr += FLASH_BLOCK_SIZE) {
// 1. Apaga o bloco de 64 bytes (Fisicamente transforma em 0xFF)
// erase_program_memory(addr);
// 2. Grava os 64 bytes com o valor 0xAA por cima do bloco apagado
write_program_memory(addr, data_aa, FLASH_BLOCK_SIZE);
// Reativa as interrupções após concluir todo o processo na Flash
set_tris_a(0b00000001); // RA0 como entrada
setup_adc_ports(NO_ANALOGS);
start_4000();
It didn't work. |
Posted: Mon Sep 28, 2026 10:38 am |
| What compiler version??? |
vtrx
Posted: Mon Sep 28, 2026 10:39 am |
5.115
From address 0x4000 onwards, the data becomes 00. |
vtrx
Posted: Mon Sep 28, 2026 7:21 pm |
Upon analysis, the problem is likely the use of the PICkit 2 programmer with a `devicedat` file modified for the 18F45K50.
There must be an error in the fuse settings, as programming works perfectly if I use the 18F4550.
I’m going to buy another programmer. |
Posted: Tue Sep 29, 2026 12:04 am |
Ah.
Thanks for coming back, I was starting to work my way through the
assembler generated, to see if there was anything obvious wrong.  |
