JAM2014
| SPI trouble with MAX31856 |
Posted: Thu Mar 19, 2026 4:06 pm |
Hi All,
Compiler Version: PCH v5.120
PIC: 18LF25K50, running at 3.3V
SPI Peripheral: MAX31856 (thermocouple to digital converter), also 3.3V
MAX31856 datasheet: https://www.analog.com/media/en/technical-documentation/data-sheets/max31856.pdf
I'm working with SPI for the first time, and not getting the expected results.
Here are the relevant pin connections:
PIC SDO (pin 24) ---> MAX SDI (pin 12)
PIC SDI (pin 21) <--- MAX SDO (pin 11)
PIC SCK (pin 22) ---> MAX SCK (pin 10)
PIC CS (pin 23) ---> MAX CS (pin 9)
Relevant code:
// Max31856 Register Addresses
#define REG_CR0 0x00 // Control Reg. 1
#define REG_CR1 0x01 // Control Reg. 2
#define REG_LTCBH 0x0C // Linearized TC Temperature, Byte 2
#define REG_LTCBM 0x0D // Linearized TC Temperature, Byte 1
#define REG_LTCBL 0x0E // Linearized TC Temperature, Byte 0
//Here we setup SPI1
#use spi(MASTER, SPI1, MODE=3, BITS=8, STREAM=MAX31856)
void max31856_write(unsigned int8 reg, unsigned int8 value) {
output_low(TC_CS);
delay_us(2);
spi_xfer(MAX31856, reg | 0x80); // Set write bit
spi_xfer(MAX31856, value);
delay_us(2);
output_high(TC_CS);
unsigned int8 max31856_read(unsigned int8 reg) {
unsigned int8 value;
output_low(TC_CS);
delay_us(2);
spi_xfer(MAX31856, reg & 0x7F); // Clear write bit
value = spi_xfer(MAX31856, 0);
delay_us(2);
output_high(TC_CS);
return value;
float GetTCData(){
//This routine uses the native CCS SPI routines to read the three temperature registers on the MAX31856 device...
float TCtemp;
unsigned int8 HighVal, MidVal, LowVal;
signed int32 RawData;
// Configure: CR0 = 0x00 (No fault auto-detect), CR1 = 0x07 (T-type)
max31856_write(REG_CR0, 0x00);
max31856_write(REG_CR1, 0x07);
// Read 3-byte temperature data (linearized)
output_low(TC_CS);
delay_us(2);
spi_xfer(MAX31856, REG_LTCBH & 0x7F);
HighVal = spi_xfer(MAX31856, 0);
MidVal = spi_xfer(MAX31856, 0);
LowVal = spi_xfer(MAX31856, 0);
delay_us(2);
output_high(TC_CS);
fprintf(Console, "Hi:%u Mid:%u Low:%u\n\r", HighVal, MidVal, LowVal);
// Convert to Celsius: Sign-extend and divide by 128
RawData = ((int32)HighVal << 16) | ((int32)MidVal << 8) | LowVal;
if(RawData & 0x800000) RawData |= 0xFF000000; // Handle negative
TCtemp = (float)RawData / 128.0;
return TCtemp;
When I call GetTCData(), it returns the three data bytes, High, Mid and Low, as all 0's. I put a scope on the CS connection, and I am seeing the CS line being asserted. I'm also seeing clock activity on the SCK line.
Based on the MAX31856 data sheet, I believe that SPI mode 3 is correct, but I'm not 100% sure of that. Other modes do not seem to work!
I'm using the SOIC version of the 18LF25K50, and I believe I've got the correct pins for hardware SPI on this device.
Any thoughts on what I might be doing wrong?
Thanks!
Jack |
Posted: Fri Mar 20, 2026 7:52 am |
First thing, are your turning off the analog on these pins?. On most
of the later PIC's, analog functions have priority over logic.
Then specify a clock rate for the SPI. The default will be as fast as
possible. You don't tell us your clock rate, but you might be pushing
the speed the Maxim chip supports.
The data sheet disagrees with itself on the clocking of the SPI. The diagram
on page 6 looks to be showing mode 3, but the diagrams on page 16, show
Mode 0. The description on page 15, says it actually supports both, and
adjusts based on the polarity of the clock when CS drops.
Big thing have you noticed the register address changes?. The register
numbers have to have bit 7 set for a write. Effectively they treat this
bit like the read/write bit for I2C.
You don't tell us what numbers you are actually using. This may be the
problem.
As a generic comment use make16 and make32, rather than the rotations
you show. Much less likely to have problems. |
JAM2014
Posted: Fri Mar 27, 2026 1:52 pm |
Hi All,
Thanks, Ttelmah, for your suggestions! I got it working by making a few changes and cleaning up a few things!
Fixes:
First, I changed the SPI clock speed to 1MHz. The MAX31856 may go faster, but it's not needed for my application, and things are rock solid at that speed!
Second, the MAX31856 has both 'polled' and 'auto acquisition' modes. I wasn't actually triggering a reading, so the result was always zero...
Clean-ups:
I was manipulating the high bit of the control registers to switch between reading and writing, but that wasn't super clear. I've now defined a 'Read' and a 'Write' address for each register to improve clarity.
Rather than three separate 8 bit reads, I now read all 24 data bits in one SPI transfer, and that seems to work just grand!
I will post the revised working code to this thread next week when I'm back in the office!
Thanks,
Jack |
Joined: 01 Jul 2010 Posts: 9658 Location: Greensville,Ontario
Posted: Fri Mar 27, 2026 4:38 pm |
great to hear it's 'up and running' !
FWIW, please add comments at the end of most of your lines of code. I got into that habit doing Assembler decades ago....
While you know NOW what 'this and that' does, 3 months from now, heck 3 weeks from now, you'll be scratching your head saying 'WHAT did I do this for ???? |
Posted: Sat Mar 28, 2026 2:00 am |
Well done.
Second the comment on remarks. These are your friend, both in actually
recording what you are doing, and in the occasions when you 'come back'
to things ages later.
On speed, even when chips 'support; a speed, a real board may not
actually work at that rate. 1MHz, sounds a very sensible rate.  |
Posted: Sat Mar 28, 2026 9:31 am |
Congratulations.
Regarding SPI speed, just want to echo Ttelmah. In order to achieve a high (and stable) SPI speed requires that the PCB be routed appropriately. Poor layouts should be able to achieve 2MHz without too much issue, and up to 4 or 5MHz for layouts that aren't quite right but aren't egregiously wrong. Getting up into the 10s of MHz requires very careful consideration.
Data sheet maximum speed does not necessarily mean you'll be able to run the interface at that speed. |
Gabriel
Posted: Sun Jul 05, 2026 9:34 am |
Late in this post, but ive had TERRIBLE experiences with the MAX31856.
Inaccurate and noisy readings.
Ok for a quick project, but not good for a legit device.
I switched over to the MCP9600 - smooth sailing since.
Posted: Tue Jul 07, 2026 5:11 pm |
yeesh 19 bits !!! getting 16 bit ADCs was hard enough in the 'dinodayze'.....
I suspect the analog section of PCB has to be better than 'textbook' ! |
Posted: Wed Jul 08, 2026 12:00 pm |
Though I agree, you have to be slightly careful to distinguish between
absolute and trend ADC's. Building circuitry to amplify and measure
signals with the former to a particular level of accuracy is many orders
of magnitude harder than the latter. For the latter, drift does not matter,
and measurements are not accurately repeatable.
In this particular case, the ADC's involved are radiometric, looking
for a change in a resistive divider, not for an absolute voltage value.
Makes it a lot easier. Also, though the ADC value is quoted at a high
number of bits, the overall accuracy is only around 1/1000 best case. |
