It is interesting. If you build with the old compiler (don't have this one, but
one quite close), it uses the same access maths when using a temporary
variable. I was hoping this would change.
webgiorgio
Posted: Wed Nov 10, 2021 8:57 am
CCS support gave me the solution
The issue is that version 5.034 is incorrectly setting the SDISEL bit in the APFCON1 register, and that is causing it not to work. This issue was fixed in newer versions of the compiler. You can work around it in your version by creating a variable mapped to the location of the SDISEL bit as follows:
#bit SDISEL = getenv("SFR:APFCON1").3
Then setting SDISEL to 0 at the beginning of main() as follows:
SDISEL = 0;
Posted: Wed Nov 10, 2021 11:03 am
That's interesting. PCM's code from 5.034, doesn't seem to have this
bit set.
Page 2 of 2
