pic i2c slave is "not found"
Goto page Previous  1, 2
PostPosted: Wed Nov 10, 2021 6:25 am     Reply with quote
It is interesting. If you build with the old compiler (don't have this one, but
one quite close), it uses the same access maths when using a temporary
variable. I was hoping this would change.
webgiorgio
PostPosted: Wed Nov 10, 2021 8:57 am     Reply with quote
CCS support gave me the solution Very Happy
The issue is that version 5.034 is incorrectly setting the SDISEL bit in the APFCON1 register, and that is causing it not to work. This issue was fixed in newer versions of the compiler. You can work around it in your version by creating a variable mapped to the location of the SDISEL bit as follows:
#bit SDISEL = getenv("SFR:APFCON1").3
Then setting SDISEL to 0 at the beginning of main() as follows:
SDISEL = 0;
PostPosted: Wed Nov 10, 2021 11:03 am     Reply with quote
That's interesting. PCM's code from 5.034, doesn't seem to have this
bit set.
Page 2 of 2
