webgiorgio
| PIC16F1789 won't program at 3.3V, but programs at 5V |
Posted: Sat Nov 06, 2021 11:00 am |
I have a PIC16F1789 that I want to operate at 3.3V (as there will be other 3.3V devices in the circuit).
I can program it at 5V (Vcc), and then it will run at 3.3V (Vcc) (simple blinking LED).
The problem is that the chip won't program at 3.3V. I get "Download Failed", diagnostics can't read the chip id. Vdd is 3.3V.
I am using a ICD-U64 programmer. For the tests I am powering the target from the programmer (selecting the jumper for 5V or 3.3V).
I understood that I am using the "high voltage programming" method.
I use
#fuses NOLVP
#use delay(clock=8M) |
webgiorgio
Posted: Wed Nov 10, 2021 2:12 pm |
How can I disable "block erase"?
I read that the chip can be programmed at 3.3V using a "normal erase" of the memory rather than "block erase". |
Posted: Tue Nov 16, 2021 3:47 am |
In the CCSload program, on the right you will see Options.
Click on the little double arrow, and it will give you more options.
It will show the Erase Mode options, which are:
- Bulk erase chip before programming
- Erase only blocks in hex file
Pick the one you want.
You can click on "make these settings be the default" on the
right side of the window. |
