opvini
onKeyUp method and deboucing for buttons - VBtn Library |
Posted: Thu Sep 06, 2012 12:32 am |
Hi... Well, I create a generic function to use with buttons that is very practice: the onKeyUp. It is necessary just create a int variable to each button, like below (here I just use 2 buttons):
The DEBOUCING was implemented:
// VBtn.c
// Buttons Treatment Including:
// Deboucing, onKeyUp, onKeyPress
// Federal University of Ouro Preto - UFOP
// Automation Engineer Department
// Developed by:
// Vinicius Nunes Lage
// email: viniciusop[ @ ]gmail.com
// Class 09.1
// Last Modification: 29/04/2014
// DEFINES:
// MAX_DEBOUNCING filter to debouncing
// SHARED API:
// vbtn_init(VBtn, pin)
// - initialize the VBtn with the pin
// vbtn_input(VBtn)
// - similar to the function input(), but with debouncing
// vbtn_onKeyUp(VBtn)
// - onKeyUp event on VBtn
// vbtn_onKeyPress(VBtn)
// - onKeyPress event on VBtn
#ifndef MAX_DEBOUNCING
#define MAX_DEBOUNCING 400
struct VBtn{
int16 pin;
int1 key_pressed;
int1 key_up;
int1 key_press;
int16 dbc_count;
// novo input() com debouncing
int1 vbtn_input(struct VBtn *btn)
if (!btn->key_pressed && input(btn->pin) && ++btn->dbc_count > MAX_DEBOUNCING)
btn->dbc_count = 1;
btn->key_pressed = 1;
else if (!input(btn->pin)) btn->key_pressed = 0;
return (btn->key_pressed);
int1 vbtn_onKeyUp( struct VBtn *btn ){
if( (btn->key_up==0) && !vbtn_input(btn->pin) ) { btn->key_up = 1; return(0); }
else if( (btn->key_up==1) && vbtn_input(btn->pin)) { btn->key_up = 0; return(1); }
else return(0);
int1 vbtn_onKeyPress( struct VBtn *btn ){
if( !btn->key_press && !vbtn_input(btn->pin) ){ btn->key_press = 1; return(1); }
else if (btn->key_press && vbtn_input(btn->pin)) { btn->key_press = 0; return(0); }
else return(0);
void init_vbtn(struct VBtn *btn, int16 PIN){
btn->pin = PIN;
btn->key_up = 0;
btn->key_press = 0;
btn->dbc_count = 0;
//////////////////////////////////////////////////// END
SIMPLE EXAMPLE (pic 18F4550):
// EXAMPLE_VBtn.c
#include <18f4550.h>
// biblioteca para trabalhar com botoes
// incluindo debouncing, onKeyUp e onKeyPress
#include "VBtn.c"
#fuses HS
#use rs232(baud=9600, parity=N, bits=8, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
void main(){
// declaration of 2 VButtons: btn1 and btn2
struct VBtn btn1, btn2;
// initialize btn1 and btn2 and set PIN_B7 and PIN_B6 to them
init_vbtn(&btn1, PIN_B7);
init_vbtn(&btn2, PIN_B6);
while(1){
// example using input with debouncing
if( vbtn_input(&btn1) ) output_high(PIN_A0);
else output_low(PIN_A0);
if( vbtn_input(&btn2) ) output_high(PIN_A1);
else output_low(PIN_A1);
Say if it is good for you!
Thanks!!!
EDITED: included deboucing
asmboy
Posted: Wed Sep 19, 2012 12:23 pm |
How do you set deadband between presses
and validate actual press down time, to avoid bouncing with dirty contacts?? |
opvini
Posted: Mon Nov 12, 2012 5:06 am |
Hi asmboy...
I really do not treat the issue of dirt or poor contact of the buttons. But you can implement this using delay...
I make a new code, more complete:
struct struct_btn{
int16 pin;
int1 key_up;
int1 key_press;
} btn1, btn2, btn3, btn4;
int1 onKeyUp( struct struct_btn *btn ){
if( (btn->key_up==0) && !INPUT(btn->pin) ) { btn->key_up = 1; return(0); }
else if( (btn->key_up==1) && INPUT(btn->pin)) { btn->key_up = 0; return(1); }
else return(0);
int1 onKeyPress( struct struct_btn *btn ){
if( !btn->key_press && !INPUT(btn->pin) ){ btn->key_press = 1; return(1); }
else if (btn->key_press && INPUT(btn->pin)) { btn->key_press = 0; return(0); }
else return(0);
// example using 2 buttons
int adm_onKeyUp(){
if( onKeyUp( &btn1 ) ) return(1);
else if( onKeyUp( &btn2 ) ) return(2);
else return(0);
int adm_onKeyPress(){
if( onKeyPress( &btn3 ) ) return(1);
else if( onKeyPress( &btn4 ) ) return(2);
else return(0);
void main(){
//************************** initializing
btn1.pin = PIN_A3;
btn1.key_up = 0;
btn1.key_press = 0;
btn2.pin = PIN_A1;
btn2.key_up = 0;
btn2.key_press = 0;
btn3.pin = PIN_A4;
btn3.key_up = 0;
btn3.key_press = 0;
btn4.pin = PIN_A2;
btn4.key_up = 0;
btn4.key_press = 0;
while(1){
// returns 1 or 2 (button 1 or button 2 with keyUp)
adm_onKeyUp();
// returns 1 or 2 (button 1 or button 2 with keyPress)
adm_onKeyPress()
opvini
Bouncing treatment now |
Posted: Tue Apr 29, 2014 4:37 pm |
Hi asmboy,
Now I implement the bouncing treatment.
The full code is below.
I called the simple library "VBtn":
// VBtn.c
// Developed by:
// Class 09.1
// DEFINES:
// SHARED API:
// vbtn_input(VBtn)
struct VBtn{
int16 pin;
int1 key_pressed;
int1 key_up;
int1 key_press;
int16 dbc_count;
btn->dbc_count = 1;
else return(0);
else return(0);
btn->pin = PIN;
btn->key_up = 0;
btn->key_press = 0;
btn->dbc_count = 0;
// EXAMPLE_VBtn.c
#include "VBtn.c"
#fuses HS
void main(){
while(1){
asmboy
Posted: Thu May 15, 2014 3:03 pm |
after a brief experiment it becomes clear that
while functional and determinate as written,
the debounce timing produced can be
inconsistent as well as variable and
is influenced by:
1- how often the check function is called.
2- how many buttons are being monitored
3-clock frequency
4- number of interrupts, and their call frequency
5-"sidetracking" by calls from main
in specific - i have ALWAYS preferred to time button up/down dynamics
with a spare system timer and a simple BYTE check[4]
(for 4 buttons ) comparison table that counts down each table element to zero on a multiple of appx 10 msecs from said system timer. |
