| sshahryiar
				| MCP23S17 16 Bit SPI IO Expander Driver |
				|  Posted: Wed Oct 02, 2013 10:13 am |   |
				| MCP23S17.h
  	  | Code: |  	  | #use SPI (MASTER, DO = PIN_B1, DI = PIN_B3, CLK = PIN_B0, BITS = 8, Mode = 0)
 #define IO_DEVICE_ADDRESS_WRITE   0x40
 #define IO_DEVICE_ADDRESS_READ    0x41
 #define IODIRA        0x00      //Data Direction Register for PORTA
 #define IODIRB        0x01      //Data Direction Register for PORTB
 #define IPOLA         0x02      //Input Polarity Register for PORTA
 #define IPOLB         0x03      //Input Polarity Register for PORTB
 #define GPINTENA      0x04      //Interrupt-on-change enable Register for PORTA
 #define GPINTENB      0x05      //Interrupt-on-change enable Register for PORTB
 #define DEFVALA       0x06      //Default Value Register for PORTA
 #define DEFVALB       0x07      //Default Value Register for PORTB
 #define INTCONA       0x08      //Interrupt-on-change control Register for PORTA
 #define INTCONB       0x09      //Interrupt-on-change control Register for PORTB
 #define IOCON         0x0A      //Configuration register for device
 #define GPPUA         0x0C      //100kOhm pullup resistor register for PORTA (sets pin to input when set)
 #define GPPUB         0x0D      //100kOhm pullup resistor register for PORTB (sets pin to input when set)
 #define INTFA         0x0E      //Interrupt flag Register for PORTA
 #define INTFB         0x0F      //Interrupt flag Register for PORTB
 #define INTCAPA       0x10      //Interrupt captured value Register for PORTA
 #define INTCAPB       0x11      //Interrupt captured value Register for PORTB
 #define GPIOA         0x12      //General purpose I/O Register for PORTA
 #define GPIOB         0x13      //General purpose I/O Register for PORTB
 #define OLATA         0x14      //Output latch Register for PORTA
 #define OLATB         0x15      //Output latch Register for PORTB
 #define CS           pin_B2
 void setup_MCP23S17();
 void MCP23S17_write(unsigned char address, unsigned char value);
 unsigned char MCP23S17_read(unsigned char address);
 MCP23S17.c
  	  | Code: |  	  | #include "MCP23S17.h"
 MCP23S17_write(IOCON, 0x18);
 MCP23S17_write(IODIRA, 0x00);
 MCP23S17_write(IODIRB, 0xFF);
 MCP23S17_write(GPPUA, 0x00);
 MCP23S17_write(GPPUB, 0xFF);
 MCP23S17_write(IPOLA, 0xFF);
 MCP23S17_write(IPOLB, 0x00);
 output_low(CS);
 spi_xfer(IO_DEVICE_ADDRESS_WRITE);
 spi_xfer(address);
 spi_xfer(value);
 output_high(CS);
 unsigned char received_data = 0;
 output_low(CS);
 spi_xfer(IO_DEVICE_ADDRESS_READ);
 spi_xfer(address);
 received_data = spi_xfer(0);
 output_high(CS);
 return received_data;
 Example
  	  | Code: |  	  | #include <10F200.h>
 #fuses PROTECT, NOWDT, NOMCLR
 #use delay (clock = 4MHz)
 #include "MCP23S17.c"
 void setup();
 unsigned char in = 0;
 setup();
 in = MCP23S17_read(GPIOB);
 MCP23S17_write(OLATA, in);
 void setup()
 setup_MCP23S17();
 https://www.facebook.com/MicroArena
 SShahryiar
