sshahryiar
  Joined: 05 May 2010 Posts: 94 Location: Dhaka, Bangladesh
				| MCP23S17 16 Bit SPI IO Expander Driver |
				 Posted: Wed Oct 02, 2013 10:13 am     |
				MCP23S17.h
#use SPI (MASTER, DO = PIN_B1, DI = PIN_B3, CLK = PIN_B0, BITS = 8, Mode = 0)
#define IO_DEVICE_ADDRESS_WRITE   0x40
#define IO_DEVICE_ADDRESS_READ    0x41
#define IODIRA        0x00      //Data Direction Register for PORTA
#define IODIRB        0x01      //Data Direction Register for PORTB
#define IPOLA         0x02      //Input Polarity Register for PORTA
#define IPOLB         0x03      //Input Polarity Register for PORTB
#define GPINTENA      0x04      //Interrupt-on-change enable Register for PORTA
#define GPINTENB      0x05      //Interrupt-on-change enable Register for PORTB
#define DEFVALA       0x06      //Default Value Register for PORTA
#define DEFVALB       0x07      //Default Value Register for PORTB
#define INTCONA       0x08      //Interrupt-on-change control Register for PORTA
#define INTCONB       0x09      //Interrupt-on-change control Register for PORTB
#define IOCON         0x0A      //Configuration register for device
#define GPPUA         0x0C      //100kOhm pullup resistor register for PORTA (sets pin to input when set)
#define GPPUB         0x0D      //100kOhm pullup resistor register for PORTB (sets pin to input when set)
#define INTFA         0x0E      //Interrupt flag Register for PORTA
#define INTFB         0x0F      //Interrupt flag Register for PORTB
#define INTCAPA       0x10      //Interrupt captured value Register for PORTA
#define INTCAPB       0x11      //Interrupt captured value Register for PORTB
#define GPIOA         0x12      //General purpose I/O Register for PORTA
#define GPIOB         0x13      //General purpose I/O Register for PORTB
#define OLATA         0x14      //Output latch Register for PORTA
#define OLATB         0x15      //Output latch Register for PORTB
#define CS           pin_B2
void setup_MCP23S17();
void MCP23S17_write(unsigned char address, unsigned char value);
unsigned char MCP23S17_read(unsigned char address);
MCP23S17.c
#include "MCP23S17.h"
   MCP23S17_write(IOCON, 0x18);
   MCP23S17_write(IODIRA, 0x00);
   MCP23S17_write(IODIRB, 0xFF);
   MCP23S17_write(GPPUA, 0x00);
   MCP23S17_write(GPPUB, 0xFF);
   MCP23S17_write(IPOLA, 0xFF);
   MCP23S17_write(IPOLB, 0x00);
    output_low(CS);
    spi_xfer(IO_DEVICE_ADDRESS_WRITE);
    spi_xfer(address);
    spi_xfer(value);
    output_high(CS);
    unsigned char received_data = 0;
    output_low(CS);
    spi_xfer(IO_DEVICE_ADDRESS_READ);
    spi_xfer(address);
    received_data = spi_xfer(0);
    output_high(CS);
    return received_data;
Example
#include <10F200.h>
#fuses PROTECT, NOWDT, NOMCLR
#use delay (clock = 4MHz)
#include "MCP23S17.c"
void setup();
    unsigned char in = 0;
    setup();
      in = MCP23S17_read(GPIOB);
      MCP23S17_write(OLATA, in);
void setup()
    setup_MCP23S17();
  _________________ https://www.facebook.com/MicroArena
SShahryiar |
