Sign Bit in a float
nilsener
Sign Bit in a float
PostPosted: Wed Dec 11, 2002 4:22 am     Reply with quote
Dear,
where to find the sign bit in a float variable ?
Thanks for helping
regards nilsener
Original Post ID: 9965
R.J.Hamlett
Re: Sign Bit in a float
PostPosted: Wed Dec 11, 2002 5:38 am     Reply with quote
:=Dear,
:=where to find the sign bit in a float variable ?
:=Thanks for helping
:=regards nilsener
It is the top bit of the third byte. Basically the low three bytes contain an integer, with the fourth byte containing the binary exponent. The integer is 23bits, plus the sign bit.
So:
union {
int8 b[4];
float f;
} value;
value.f=10000.0;
if (value.b[2] & 128) {
//This will test as true if the float is negative
Original Post ID: 9968
nilsener
PostPosted: Wed Dec 11, 2002 9:56 am     Reply with quote
:=:=Dear,
:=:=where to find the sign bit in a float variable ?
:=:=Thanks for helping
:=:=regards nilsener
:=It is the top bit of the third byte. Basically the low three bytes contain an integer, with the fourth byte containing the binary exponent. The integer is 23bits, plus the sign bit.
:=So:
:=union {
:= int8 b[4];
:= float f;
:=} value;
:=value.f=10000.0;
:=if (value.b[2] & 128) {
:= //This will test as true if the float is negative
:=Best Wishes
Original Post ID: 9976
