nilsener Guest
| Sign Bit in a float |
Posted: Wed Dec 11, 2002 4:22 am |
Dear,
where to find the sign bit in a float variable ?
Thanks for helping
regards nilsener
___________________________
Original Post ID: 9965 |
R.J.Hamlett Guest
| Re: Sign Bit in a float |
Posted: Wed Dec 11, 2002 5:38 am |
:=Dear,
:=where to find the sign bit in a float variable ?
:=Thanks for helping
:=regards nilsener
It is the top bit of the third byte. Basically the low three bytes contain an integer, with the fourth byte containing the binary exponent. The integer is 23bits, plus the sign bit.
So:
union {
int8 b[4];
float f;
} value;
value.f=10000.0;
if (value.b[2] & 128) {
//This will test as true if the float is negative
Original Post ID: 9968 |
nilsener Guest
Posted: Wed Dec 11, 2002 9:56 am |
:=:=Dear,
:=:=where to find the sign bit in a float variable ?
:=:=Thanks for helping
:=:=regards nilsener
:=It is the top bit of the third byte. Basically the low three bytes contain an integer, with the fourth byte containing the binary exponent. The integer is 23bits, plus the sign bit.
:=So:
:=union {
:= int8 b[4];
:= float f;
:=} value;
:=value.f=10000.0;
:=if (value.b[2] & 128) {
:= //This will test as true if the float is negative
:=Best Wishes
Original Post ID: 9976 |
