Anyone used Atmel cryptomemory AT88SCxxxx chip I2C ?
dahonig
PostPosted: Tue May 06, 2008 9:45 am     Reply with quote
Hi, I'm trying to get a PIC 16F886 to talk to an Atmel cryptomemory (tm)
chip over an I2C bus. I can talk to a regular serial eeprom ok,
using the CCS i2c functions, but the slightly different AT88SC protocol is giving me problems. I'm currently pursuing a lower-level bit
banging port but wonder if anyone has done this before.
PostPosted: Tue May 06, 2008 1:05 pm     Reply with quote
Post a link to the datasheet for the exact part number that you're using.
dahonig
AT88SC 0808C datasheet
PostPosted: Wed May 07, 2008 2:22 pm     Reply with quote
http://www.atmel.com/dyn/resources/prod_documents/doc5210.pdf
The read-out sequence may be the problem.. You have to write
a read command to an even address then read out the bytes.
I'm using the AT88SC 0808C part for learning with.
PostPosted: Thu May 08, 2008 1:17 am     Reply with quote
You have to write a read command to an even address then read out the bytes.
In addition to that, there are two other things you must do:
7.1 Start-up Sequence
When first powering up the device, 5 pulses are required on CLK-SCL for
reading of internal registers.
This is probably easiest to do if you use the CCS i2c library in software
i2c mode. You can take over the bus, send the 5 pulses on SCL, and
then restore the SCL pin to the required state with the output_float()
function.
7.4 Acknowledge Polling
Each command is ended with a stop condition. Certain commands are
required to be followed by an acknowledge polling sequence.
• Read Commands: No ACK polling required.
• Write Commands: ACK polling required except encrypted write
commands. Any command may be used.
• Set commands: No ACK polling required.
• Verify commands: ACK polling required with B2 or B6 commands only.
This appnote has some sample command sequences, starting on page 6:
http://atmel.com/dyn/resources/prod_documents/doc5051.pdf
Cryptomemory i2c
PostPosted: Mon May 12, 2008 11:06 am     Reply with quote
Thanks for the help. I ended up using a bit-banging implementation
of the I2C protocol, which was done by porting simple i2c functions
(eg void ll_Clockhigh(void)) in Atmel's ll_port.c (As you suggest)
This let me talk to the chip --both user memory and config memory.
Their authentication protocol isn't publicly documented enough to
code, but I found a FAE team at Atmel that volunteered to do
a PIC16 build of their library, and I'll be delighted with that.
Very nice when this stuff comes together --I was learning PIC
architecture, the IDE, compiler, i2c, and the atmel chips
at the same time.
I'm quite impressed how quickly the compiler & IDE get you up
and running. Also fascinated with the 'stuff more peripherals
into the component than you have pins' PIC architecture.
