Andrew911tt Guest
| need a lot of help with RFID module |
Posted: Wed Mar 12, 2008 2:26 pm |
Ok I am using a PIC16F877A and a Parallax RFID Reader Module 2814
parallax.com/Portals/0/Downloads/docs/prod/audiovis/RFID-Reader-v1.2.pdf
I am just trying to read the ID and then output it.
| Code: | #include <protoalone.h>
#include <utility.c>
#include <stdlib.h>
#include <input.c>
#use rs232 (baud=2400, parity=N, bits=8, stop=1, xmit=PIN_C3, rcv=PIN_C2, stream=RFID)
#use rs232 (baud=9600, xmit=PIN_C6, rcv=PIN_C7, stream=COMP)
#define RFID_ON PIN_C1
char string_a[20]="no ID";
fprintf(COMP,"\r\n%s",string_a);
output_low (RFID_ON);
gfgets(string_a,RFID);
output_high (RFID_ON);
Posted: Wed Mar 12, 2008 5:18 pm |
Where is the code for gfgets()?
What is your question? |
Posted: Wed Mar 12, 2008 5:33 pm |
You didn't show your #fuses statement. It might have problems.
But at a minimum, you need to add a while(1); statement at the end
of main(). The compiler puts a hidden sleep instruction there. Without
that statement, you will miss the last two characters of your ID value. |
Posted: Wed Mar 12, 2008 5:34 pm |
| ckielstra wrote: | Where is the code for gfgets()?
Sorry that is suppose to be fgets() typo when posting here
Why is it not working i think it has some thing to do with fgets() or the #use rs232 for the rfid |
