variables in function calls
Felix Althaus
PostPosted: Sat Sep 08, 2001 8:49 am     Reply with quote
Hello (Grüezi)
I wrote the following code to print a character on a LCD-modul (only a part of the code is shown here):
#byte BUS = 6
#separate
void put_to_lcd(char value)
BUS = value;
etc.
//example:
main()
put_to_lcd('A');
my problem: the compiler loads the argument of the function first to a normal RAM-location and then (during the function) to the PORTB.
Is there any possibility to load the argument directly to the PORTB without it loading first to an other location?
Greetings from Switzerland
Felix
___________________________
Original Post ID: 215
Tomi
Re: variables in function calls
PostPosted: Sat Sep 08, 2001 10:13 am     Reply with quote
The problem is about parameter passing to a function. It is done either using physical stack (Neumann processor) or a software stack (Harward proc. e.g. PIC). This SW stack in a PIC looks like a "normal RAM-location".
To bypass the usage of the stack you can use a #define instead of a function:
#byte BUS = 6
#define put_to_lcd(value) BUS=value
Sample code:
.................... put_to_lcd('A');
004B: MOVLW 41
004C: MOVWF 06
To make sure that the port_B is output you can extend the statement:
#byte BUS = 6
#define put_to_lcd(value) Set_Tris_B(0);BUS=value
Sample:
004B: MOVLW 00
004C: BSF 03,5
004D: MOVWF 06
004E: MOVLW 41
004F: BCF 03,5
0050: MOVWF 06
:=Hello (Grüezi)
:=I wrote the following code to print a character on a LCD-modul (only a part of the code is shown here):
:=#byte BUS = 6
:=#separate
:=void put_to_lcd(char value)
:= BUS = value;
:= etc.
:=//example:
:=main()
:=put_to_lcd('A');
:=my problem: the compiler loads the argument of the function first to a normal RAM-location and then (during the function) to the PORTB.
:=Is there any possibility to load the argument directly to the PORTB without it loading first to an other location?
:=Thanks
:=Greetings from Switzerland
:=Felix
Original Post ID: 216
