ICD-U40 can't connect with PC
stefan_d6
PostPosted: Sat Dec 16, 2006 5:35 am     Reply with quote
I've got a new ICD-U40.
I installed its drivers (setup_usbdrivers.exe) and the PC recognizes it with no problems - CCS ICD-U40 in Device Menager. Then I installed ICD.exe (setup_icd.exe). My PCW is v.3.235.
But when I try to run ICD.exe a message occurs:
Access violation at address 01225287 in module "ftd2xx.dll". Write of address 01270000
and after confirming the window Start Connection appears but only with two possible choices - COM1 and COM2. Neither of them works.
Where is the problem
stefan_d6
PostPosted: Sat Dec 16, 2006 6:31 am     Reply with quote
I solved the problem.
It seems the new driver from www.ccsinfo.com is not for my ICD-U40. I used the old one -DriverVer=10/15/2004,1.06.20
