Multiple SPI Slave
thomas
Multiple SPI Slave
PostPosted: Sun Aug 10, 2003 9:13 pm     Reply with quote
Hi everyone,
As you know, the PIC has only 1 SPI port. It can send data to multiple slaves. How can I configure it so that it can receive data from multiple slaves?
Regards,
Thomas
___________________________
Original Post ID: 144516867
Charlie U
Re: Multiple SPI Slave
PostPosted: Sun Aug 10, 2003 11:22 pm     Reply with quote
:=Hi everyone,
:=As you know, the PIC has only 1 SPI port. It can send data to multiple slaves. How can I configure it so that it can receive data from multiple slaves?
:=Regards,
:=Thomas
Check the devices you plan to use. Most, if not all, have a Chip Select input that selects the device when you wish to communicate with it. Just connect these Chip Selects to pins on you PIC and use them to select the proper device at the proper time and you can then use a single SPI interface.
Original Post ID: 144516868
thomas
PostPosted: Mon Aug 11, 2003 12:24 am     Reply with quote
I understand this, but my point is, if multiple slaves' SDO outputs are connected to a single Master's SDI input, there will be a conflict. Let's say if slave A finished sending data to the master and its SDO signal is kept low. Now slave B wants to send data to the master, but the Master's SDI input is held low by slave A's SDO signal. Therefore, slave B can't send data to the Master properly.
Regards,
Thomas
:=:=Hi everyone,
:=:=As you know, the PIC has only 1 SPI port. It can send data to multiple slaves. How can I configure it so that it can receive data from multiple slaves?
:=:=Regards,
:=:=Thomas
:=Check the devices you plan to use. Most, if not all, have a Chip Select input that selects the device when you wish to communicate with it. Just connect these Chip Selects to pins on you PIC and use them to select the proper device at the proper time and you can then use a single SPI interface.
Original Post ID: 144516869
R.J.Hamlett
PostPosted: Mon Aug 11, 2003 3:08 am     Reply with quote
:=I understand this, but my point is, if multiple slaves' SDO outputs are connected to a single Master's SDI input, there will be a conflict. Let's say if slave A finished sending data to the master and its SDO signal is kept low. Now slave B wants to send data to the master, but the Master's SDI input is held low by slave A's SDO signal. Therefore, slave B can't send data to the Master properly.
:=Regards,
:=Thomas
A 'slave', cannot initiate a transaction. The master does this. The processor enables one slave, talks to it, and gets it's replies. A 'slave' cannot talk, till the master talks to it. The problem you are describing, would only apply on a 'multi-master' system, where you would have to add extra control lines, and protocols to prevent a clash (there have been plenty of discussions of this on the group in the past - a search should find some examples).
:=:=:=Hi everyone,
:=:=:=As you know, the PIC has only 1 SPI port. It can send data to multiple slaves. How can I configure it so that it can receive data from multiple slaves?
:=:=:=Regards,
:=:=:=Thomas
:=:=Check the devices you plan to use. Most, if not all, have a Chip Select input that selects the device when you wish to communicate with it. Just connect these Chip Selects to pins on you PIC and use them to select the proper device at the proper time and you can then use a single SPI interface.
Original Post ID: 144516874
TSchultz
RE: Multiple SPI Slave
PostPosted: Mon Aug 11, 2003 6:13 am     Reply with quote
One other item to make sure of;
Make sure the SPI slave devices you are using have a tri-stated SDO. Not all devices I have used in the past do this but most do.
Assuming that all the devices do have a tri-stated SDO then multiple slaves is simply a matter of connecting them all to the SDI pin on the PIC and then adressing the chip you want to "talk" to. Each slave will have its own chip select pin, make sure only one is selected at a time.
-Troy
:=:=Hi everyone,
:=:=Regards,
:=:=Thomas
Original Post ID: 144516880
thomas
PostPosted: Mon Aug 11, 2003 1:53 pm     Reply with quote
Yes, I know that the slave can not initiate a transaction (I think my previous reply was a little misleading). I think what I need to do is to make the SDO of the slaves high-Z so that other slaves can control the SDI line of the master properly.
Regards,
Thomas
:=:=I understand this, but my point is, if multiple slaves' SDO outputs are connected to a single Master's SDI input, there will be a conflict. Let's say if slave A finished sending data to the master and its SDO signal is kept low. Now slave B wants to send data to the master, but the Master's SDI input is held low by slave A's SDO signal. Therefore, slave B can't send data to the Master properly.
:=:=Regards,
:=:=Thomas
:=A 'slave', cannot initiate a transaction. The master does this. The processor enables one slave, talks to it, and gets it's replies. A 'slave' cannot talk, till the master talks to it. The problem you are describing, would only apply on a 'multi-master' system, where you would have to add extra control lines, and protocols to prevent a clash (there have been plenty of discussions of this on the group in the past - a search should find some examples).
:=Best Wishes
:=:=:=:=Hi everyone,
:=:=:=:=As you know, the PIC has only 1 SPI port. It can send data to multiple slaves. How can I configure it so that it can receive data from multiple slaves?
:=:=:=:=Regards,
:=:=:=:=Thomas
:=:=:=Check the devices you plan to use. Most, if not all, have a Chip Select input that selects the device when you wish to communicate with it. Just connect these Chip Selects to pins on you PIC and use them to select the proper device at the proper time and you can then use a single SPI interface.
Original Post ID: 144516895
Hans Wedemeyer
PostPosted: Mon Aug 11, 2003 5:50 pm     Reply with quote
If the slaves are other PIC's that have hardware SPI then you have no problem at all.
The Master will select each slave chicp as it needs to communicate with it.
If you use the SLAVE SELECT pin on each slave then the SDO is controlled by it. If slave is slected the SOD can be O/P if not selected it is HiZ.... no need to mess with doing it yourself.
I did a project earlier this year, one PIC18F talking to 4 PIC16F chips at 10MHz SPI.... works fine...
Original Post ID: 144516906
thomas
PostPosted: Mon Aug 11, 2003 6:34 pm     Reply with quote
Thank you for your help! This is exactly what I am looking for!
Regards,
Thomas
:=If the slaves are other PIC's that have hardware SPI then you have no problem at all.
:=The Master will select each slave chicp as it needs to communicate with it.
:=If you use the SLAVE SELECT pin on each slave then the SDO is controlled by it. If slave is slected the SOD can be O/P if not selected it is HiZ.... no need to mess with doing it yourself.
:=I did a project earlier this year, one PIC18F talking to 4 PIC16F chips at 10MHz SPI.... works fine...
Original Post ID: 144516907
