Decode serial messages
mmanisse
PostPosted: Mon Jul 28, 2003 3:52 am     Reply with quote
I'm searching a suggest to implement a decode serial ascii message on my firmware.
I have a modem connect on pic 16f877 uart and i have to decode the answer messages.
Example:
I sent a command to the modem with a printf string 'AT' and i must decode the answer 'OK'.
This message always end with 'return ascii char'
How can i do?
Thank you
___________________________
Original Post ID: 144516420
Mark
Re: Decode serial messages
PostPosted: Mon Jul 28, 2003 5:55 am     Reply with quote
Read the data into a buffer until you recieve the 'return char'. Then process the buffer using a string compare function:
char string1[]="OK";
if (stricmp(buffer, string1) == 0)
//The strings are equal so do whatever
or
char string1[3]; // This must be big enough including the NULL terminator
strcpy(string1, "OK");
:=Hi,
:=I'm searching a suggest to implement a decode serial ascii message on my firmware.
:=I have a modem connect on pic 16f877 uart and i have to decode the answer messages.
:=Example:
:=I sent a command to the modem with a printf string 'AT' and i must decode the answer 'OK'.
:=This message always end with 'return ascii char'
:=How can i do?
:=Thank you
Original Post ID: 144516427
Steve H.
What I do....
PostPosted: Mon Jul 28, 2003 7:54 am     Reply with quote
I have similar code posted on my website at the link below.
Steve H.
Original Post ID: 144516432
jpt@tayloredge.com
PostPosted: Mon Jul 28, 2003 8:24 pm     Reply with quote
<a href="http://www.tayloredge.com/utilities/scmd.c.txt" TARGET="_blank">http://www.tayloredge.com/utilities/scmd.c.txt</a>
from
<a href="http://www.tayloredge.com/utilities/index.html" TARGET="_blank">http://www.tayloredge.com/utilities/index.html</a>
This is my command processor, all interrupt level message decode.
Original Post ID: 144516450
mmanisse
PostPosted: Sat Aug 02, 2003 3:16 am     Reply with quote
ok Mark
i untherstood what do you mean, but i have a little difficoult to do this.
My strategy to decode message is this:
my modem message always is:
'CR' 'LF' 'MESSAGE' 'CR' 'LF'.
With this information i'm working in this mode:
I'm looking for the CR and LF than i buffered the chars to next CR.
Now i have a buffer, how can i compare it?
Tnx
I'm attach the function:
gsm_rx_string()
//Rx string from gsm: 'CR' 'LF' 'XXXXXXXXXX' 'CR' 'LF'
MESSAGE_READ=0;
buffer_gsm=0;
buffer_gsm[0] = getc();
if (buffer_gsm[0] != 'CR') // Find Carriage Return.
goto exit;
if (buffer_gsm[0] != 'LF') // Find Line Feed.
goto exit;
i=0; // Buffered the string to next CR
do {
buffer_gsm[i] = getc();
++i;
} while ((buffer_gsm[i-1] != 'CR') || (i<35));
if ((buffer_gsm[i-1] == 'CR') && (i>0))
MESSAGE_READ=1;
i=i-1; // Delete CR from string.
exit:
:=Read the data into a buffer until you recieve the 'return char'. Then process the buffer using a string compare function:
:=char string1[]="OK";
:=if (stricmp(buffer, string1) == 0)
:= //The strings are equal so do whatever
:=or
:=char string1[3]; // This must be big enough including the NULL terminator
:=strcpy(string1, "OK");
:=:=Hi,
:=:=I'm searching a suggest to implement a decode serial ascii message on my firmware.
:=:=I have a modem connect on pic 16f877 uart and i have to decode the answer messages.
:=:=Example:
:=:=I sent a command to the modem with a printf string 'AT' and i must decode the answer 'OK'.
:=:=This message always end with 'return ascii char'
:=:=How can i do?
:=:=Thank you
Original Post ID: 144516588
Mark
PostPosted: Sat Aug 02, 2003 9:36 am     Reply with quote
Try this out:
enum message
MSG_OK,
MSG_TEST,
MSG_3,
MSG_4,
MSG_5,
MSG_6,
INVALID_MSG
gsm_rx_string()
MESSAGE_READ=0;
buffer_gsm[0]=0;
if (buffer_gsm[0] != '\r') // Find Carriage Return.
return;
if (buffer_gsm[0] != '\n') // Find Line Feed.
return;
i=0;
while(i<35)
if (buffer_gsm[i] == '\r')
// terminate our string
buffer_gsm[i] = 0
MESSAGE_READ=1;
i++;
return;
enum message Check_GSM_String(char *s1)
enum message msg;
char s2[10]; // This must be big enough including the NULL terminator
for (msg=0;msg {
switch (msg)
case MSG_OK:
strcpy(s2, "OK");
case MSG_TEST:
strcpy(s2, "TEST");
case MSG_MSG3:
strcpy(s2, "MSG3");
case MSG_MSG4:
strcpy(s2, "MSG4");
case MSG_MSG5:
strcpy(s2, "MSG5");
case MSG_MSG6:
strcpy(s2, "MSG6");
default:
// we shouldn't ever get here! But if we do return invalid message
return(INVALID_MSG);
if (stricmp(s1, s2) == 0)
//The strings are equal so return which one
return(msg);
// We didn't find a valid message so return an invalid one
:=ok Mark
:=i untherstood what do you mean, but i have a little difficoult to do this.
:=My strategy to decode message is this:
:=my modem message always is:
:='CR' 'LF' 'MESSAGE' 'CR' 'LF'.
:=With this information i'm working in this mode:
:=I'm looking for the CR and LF than i buffered the chars to next CR.
:=Now i have a buffer, how can i compare it?
:=Tnx
:=I'm attach the function:
:=gsm_rx_string()
:=//Rx string from gsm: 'CR' 'LF' 'XXXXXXXXXX' 'CR' 'LF'
:= MESSAGE_READ=0;
:= buffer_gsm=0;
:= buffer_gsm[0] = getc();
:= if (buffer_gsm[0] != 'CR') // Find Carriage Return.
:= goto exit;
:= if (buffer_gsm[0] != 'LF') // Find Line Feed.
:= goto exit;
:= i=0; // Buffered the string to next CR
:= do {
:= buffer_gsm[i] = getc();
:= ++i;
:= } while ((buffer_gsm[i-1] != 'CR') || (i<35));
:= if ((buffer_gsm[i-1] == 'CR') && (i>0))
:= MESSAGE_READ=1;
:= i=i-1; // Delete CR from string.
:=exit:
:=:=Read the data into a buffer until you recieve the 'return char'. Then process the buffer using a string compare function:
:=:=char string1[]="OK";
:=:=if (stricmp(buffer, string1) == 0)
:=:= //The strings are equal so do whatever
:=:=or
:=:=char string1[3]; // This must be big enough including the NULL terminator
:=:=strcpy(string1, "OK");
:=:=:=Hi,
:=:=:=I'm searching a suggest to implement a decode serial ascii message on my firmware.
:=:=:=I have a modem connect on pic 16f877 uart and i have to decode the answer messages.
:=:=:=Example:
:=:=:=I sent a command to the modem with a printf string 'AT' and i must decode the answer 'OK'.
:=:=:=This message always end with 'return ascii char'
:=:=:=How can i do?
:=:=:=Thank you
Original Post ID: 144516592
mmanisse
PostPosted: Sun Aug 03, 2003 6:29 am     Reply with quote
Ok Mark,
I have introducted you suggest in my firmware, but the compiler tell me that there is an error on :
'enum message msg;'
It espect a {
This is the first time that i use enum, do you think that there is an error?
I have counted the {} but all opened are closed.
Can you help me?
:=Try this out:
:=enum message
:= MSG_OK,
:= MSG_TEST,
:= MSG_3,
:= MSG_4,
:= MSG_5,
:= MSG_6,
:= INVALID_MSG
:=gsm_rx_string()
:= MESSAGE_READ=0;
:= buffer_gsm[0]=0;
:= if (buffer_gsm[0] != '\r') // Find Carriage Return.
:= return;
:= if (buffer_gsm[0] != '\n') // Find Line Feed.
:= return;
:= i=0;
:= while(i<35)
:= if (buffer_gsm[i] == '\r')
:= // terminate our string
:= buffer_gsm[i] = 0
:= MESSAGE_READ=1;
:= break;
:= i++;
:= return;
:=enum message Check_GSM_String(char *s1)
:= enum message msg;
:= char s2[10]; // This must be big enough including the NULL terminator
:= for (msg=0;msg := {
:= switch (msg)
:= case MSG_OK:
:= strcpy(s2, "OK");
:= break;
:= case MSG_TEST:
:= strcpy(s2, "TEST");
:= break;
:= case MSG_MSG3:
:= strcpy(s2, "MSG3");
:= break;
:= case MSG_MSG4:
:= strcpy(s2, "MSG4");
:= break;
:= case MSG_MSG5:
:= strcpy(s2, "MSG5");
:= break;
:= case MSG_MSG6:
:= strcpy(s2, "MSG6");
:= break;
:= default:
:= // we shouldn't ever get here! But if we do return invalid message
:= return(INVALID_MSG);
:= if (stricmp(s1, s2) == 0)
:= //The strings are equal so return which one
:= return(msg);
:= // We didn't find a valid message so return an invalid one
:=:=ok Mark
:=:=i untherstood what do you mean, but i have a little difficoult to do this.
:=:=My strategy to decode message is this:
:=:=my modem message always is:
:=:='CR' 'LF' 'MESSAGE' 'CR' 'LF'.
:=:=With this information i'm working in this mode:
:=:=I'm looking for the CR and LF than i buffered the chars to next CR.
:=:=Now i have a buffer, how can i compare it?
:=:=Tnx
:=:=I'm attach the function:
:=:=gsm_rx_string()
:=:=//Rx string from gsm: 'CR' 'LF' 'XXXXXXXXXX' 'CR' 'LF'
:=:= MESSAGE_READ=0;
:=:= buffer_gsm=0;
:=:= buffer_gsm[0] = getc();
:=:= if (buffer_gsm[0] != 'CR') // Find Carriage Return.
:=:= goto exit;
:=:= if (buffer_gsm[0] != 'LF') // Find Line Feed.
:=:= goto exit;
:=:= i=0; // Buffered the string to next CR
:=:= do {
:=:= buffer_gsm[i] = getc();
:=:= ++i;
:=:= } while ((buffer_gsm[i-1] != 'CR') || (i<35));
:=:= if ((buffer_gsm[i-1] == 'CR') && (i>0))
:=:= MESSAGE_READ=1;
:=:= i=i-1; // Delete CR from string.
:=:=exit:
:=:=:=Read the data into a buffer until you recieve the 'return char'. Then process the buffer using a string compare function:
:=:=:=char string1[]="OK";
:=:=:=if (stricmp(buffer, string1) == 0)
:=:=:= //The strings are equal so do whatever
:=:=:=or
:=:=:=char string1[3]; // This must be big enough including the NULL terminator
:=:=:=strcpy(string1, "OK");
:=:=:=:=Hi,
:=:=:=:=I'm searching a suggest to implement a decode serial ascii message on my firmware.
:=:=:=:=I have a modem connect on pic 16f877 uart and i have to decode the answer messages.
:=:=:=:=Example:
:=:=:=:=I sent a command to the modem with a printf string 'AT' and i must decode the answer 'OK'.
:=:=:=:=This message always end with 'return ascii char'
:=:=:=:=How can i do?
:=:=:=:=Thank you
Original Post ID: 144516620
Mark
PostPosted: Sun Aug 03, 2003 8:20 am     Reply with quote
Typo, you need a ; after the }
enum message
MSG_OK,
MSG_TEST,
MSG_3,
MSG_4,
MSG_5,
MSG_6,
INVALID_MSG
:=Ok Mark,
:=I have introducted you suggest in my firmware, but the compiler tell me that there is an error on :
:='enum message msg;'
:=It espect a {
:=This is the first time that i use enum, do you think that there is an error?
:=I have counted the {} but all opened are closed.
:=Can you help me?
:=:=Try this out:
:=:=enum message
:=:= MSG_OK,
:=:= MSG_TEST,
:=:= MSG_3,
:=:= MSG_4,
:=:= MSG_5,
:=:= MSG_6,
:=:= INVALID_MSG
:=:=gsm_rx_string()
:=:= buffer_gsm[0]=0;
:=:= if (buffer_gsm[0] != '\r') // Find Carriage Return.
:=:= return;
:=:= if (buffer_gsm[0] != '\n') // Find Line Feed.
:=:= return;
:=:= i=0;
:=:= while(i<35)
:=:= if (buffer_gsm[i] == '\r')
:=:= // terminate our string
:=:= buffer_gsm[i] = 0
:=:= break;
:=:= i++;
:=:= return;
:=:=enum message Check_GSM_String(char *s1)
:=:= enum message msg;
:=:= char s2[10]; // This must be big enough including the NULL terminator
:=:= for (msg=0;msg :=:= {
:=:= switch (msg)
:=:= case MSG_OK:
:=:= strcpy(s2, "OK");
:=:= break;
:=:= case MSG_TEST:
:=:= strcpy(s2, "TEST");
:=:= break;
:=:= case MSG_MSG3:
:=:= strcpy(s2, "MSG3");
:=:= break;
:=:= case MSG_MSG4:
:=:= strcpy(s2, "MSG4");
:=:= break;
:=:= case MSG_MSG5:
:=:= strcpy(s2, "MSG5");
:=:= break;
:=:= case MSG_MSG6:
:=:= strcpy(s2, "MSG6");
:=:= break;
:=:= default:
:=:= // we shouldn't ever get here! But if we do return invalid message
:=:= return(INVALID_MSG);
:=:= if (stricmp(s1, s2) == 0)
:=:= //The strings are equal so return which one
:=:= return(msg);
:=:= // We didn't find a valid message so return an invalid one
:=:=:=ok Mark
:=:=:=i untherstood what do you mean, but i have a little difficoult to do this.
:=:=:=My strategy to decode message is this:
:=:=:=my modem message always is:
:=:=:='CR' 'LF' 'MESSAGE' 'CR' 'LF'.
:=:=:=With this information i'm working in this mode:
:=:=:=I'm looking for the CR and LF than i buffered the chars to next CR.
:=:=:=Now i have a buffer, how can i compare it?
:=:=:=Tnx
:=:=:=I'm attach the function:
:=:=:=gsm_rx_string()
:=:=:=//Rx string from gsm: 'CR' 'LF' 'XXXXXXXXXX' 'CR' 'LF'
:=:=:= MESSAGE_READ=0;
:=:=:= buffer_gsm=0;
:=:=:= buffer_gsm[0] = getc();
:=:=:= if (buffer_gsm[0] != 'CR') // Find Carriage Return.
:=:=:= goto exit;
:=:=:= if (buffer_gsm[0] != 'LF') // Find Line Feed.
:=:=:= goto exit;
:=:=:= i=0; // Buffered the string to next CR
:=:=:= do {
:=:=:= buffer_gsm[i] = getc();
:=:=:= ++i;
:=:=:= } while ((buffer_gsm[i-1] != 'CR') || (i<35));
:=:=:= if ((buffer_gsm[i-1] == 'CR') && (i>0))
:=:=:= MESSAGE_READ=1;
:=:=:= i=i-1; // Delete CR from string.
:=:=:=exit:
:=:=:=:=Read the data into a buffer until you recieve the 'return char'. Then process the buffer using a string compare function:
:=:=:=:=char string1[]="OK";
:=:=:=:=if (stricmp(buffer, string1) == 0)
:=:=:=:= //The strings are equal so do whatever
:=:=:=:=or
:=:=:=:=char string1[3]; // This must be big enough including the NULL terminator
:=:=:=:=strcpy(string1, "OK");
:=:=:=:=:=Hi,
:=:=:=:=:=I'm searching a suggest to implement a decode serial ascii message on my firmware.
:=:=:=:=:=I have a modem connect on pic 16f877 uart and i have to decode the answer messages.
:=:=:=:=:=Example:
:=:=:=:=:=I sent a command to the modem with a printf string 'AT' and i must decode the answer 'OK'.
:=:=:=:=:=This message always end with 'return ascii char'
:=:=:=:=:=How can i do?
:=:=:=:=:=Thank you
Original Post ID: 144516623
mmanisse
PostPosted: Mon Aug 04, 2003 1:51 pm     Reply with quote
There is another compiler error
enum message msg; //Compiler error espect {????
char s2[10];
Original Post ID: 144516661
Mark
PostPosted: Mon Aug 04, 2003 5:33 pm     Reply with quote
Look at the for statement. This board doesn't like the less than sign it should read
for(msg=0;msg "less than" INVALID_MSG;msg++)
Also note that there are some typo's in the switch statement. For example, MSG_MSG3 should have been MSG_3 but it doesn't really matter since you are writing your own enums. There was another ';' missing in there also.
Regards
Mark
:=There is another compiler error
:= enum message msg; //Compiler error espect {????
:= char s2[10];
Original Post ID: 144516663
