Confusion about RTCC timing in the manual
hillcraft
PostPosted: Mon Aug 04, 2003 12:38 am     Reply with quote
<font face="Courier New" size=-1>On page 188 of the CCS manual in demo EX_STWT.C the following appears.
#use delay (clock=20000000)
#define INTS_PER_SECOND 76 // (20000000/(4*256*256))
===in code
setup_counters (RTCC_INTERNAL,RTCC_DIV_256);
Is this correct:
20000000/4 = 5000000 -> internal clock
5000000/256 = 19531.25 -> RTCC roll over
19531.25/256 = 76.294 -> RTCC_DIV_256
This is wher I get confused
On page 136 of PICmicro MCU C by Nigel Gardner the following appears;
#use delay(clock=1024000)
===in code
setup_counters(rtcc_internal,rtcc_div_256);
// increments 1024000/4*256 times per second
//or every millisecond
Is this correct:
1024000/4 = 256000 -> internal clock
256000/256 = 1000 -> RTCC roll over
-- this part of the calculation is not performed
1000/256 = 3.9 -> RTCC_DIV_256
My question is: is the example in Nigel Gardner's book incorrect because the RTCC_DIV_256 is never taken in to account?</font>
___________________________
Original Post ID: 144516638
Felix Althaus
Re: Confusion about RTCC timing in the manual
PostPosted: Mon Aug 04, 2003 3:37 am     Reply with quote
Hello
:=#use delay (clock=20000000)
:=#define INTS_PER_SECOND 76 // (20000000/(4*256*256))
:====in code
:=setup_counters (RTCC_INTERNAL,RTCC_DIV_256);
:=Is this correct:
:=20000000/4 = 5000000 -> internal clock
:=5000000/256 = 19531.25 -> RTCC roll over
:=19531.25/256 = 76.294 -> RTCC_DIV_256
Yes, I think your calculation is correct
:=This is wher I get confused
:=On page 136 of PICmicro MCU C by Nigel Gardner the following appears;
:=#use delay(clock=1024000)
:====in code
:=setup_counters(rtcc_internal,rtcc_div_256);
:=// increments 1024000/4*256 times per second
:=//or every millisecond
:=Is this correct:
:=1024000/4 = 256000 -> internal clock
:=256000/256 = 1000 -> RTCC roll over
The comment of the code sais something about incrementing every 1ms, so I think this 1000 is the incrementing frequency of tmr0 and not the roll over frequ.
:=-- this part of the calculation is not performed
:=1000/256 = 3.9 -> RTCC_DIV_256
:=My question is: is the example in Nigel Gardner's book incorrect because the RTCC_DIV_256 is never taken in to account?
I don't know this appliaction of M. Gardner but perhaps there is no tmr0-isr? And so he don't use the roll-over.
may this helps
mfg
Felix
Original Post ID: 144516641
