Wiegand to Serial Driver
Post new topic   Reply to topic    CCS Forum Index -> Code Library
chingB
PostPosted: Sat Aug 12, 2006 12:53 am     Reply with quote
I hope this simple code will help.
#byte PORTB   = 0xF81    // PortB special function register
#bit  RBPU    = 0xFF1.7  // PortB pull-ups enable bit (0-enable, 1-disable)
#bit  TMR3IF  = 0xFA1.1  // Timer3 Interrupt Flag bit
#bit  INTEDG0 = 0xFF1.6  // ext0 interrupt edge select bit
#bit  INT0IF  = 0xFF2.1  // ext0 interrupt flag bit
#bit  INTEDG1 = 0xFF1.5  // ext1 interrupt edge select bit
#bit  INT1IF  = 0xFF0.0  // ext1 interrupt flag bit
#bit  DATA0   = 0xF81.0  // data0 wiegand signal
#bit  DATA1   = 0xF81.1  // data1 wiegand signal
// PortB[0..7] weak pullups macro
#define ENABLE_PULLUPS()      RBPU=0    // enable weak pullups on PortB
#define DISABLE_PULLUPS()     RBPU=1    // disable weak pullups on PortB
#define TX_SIZE 64               // RS485 TX data size
byte TXbuffer[TX_SIZE];          // RS485 TX buffer
byte TXin  = 0;                  // RS485 TX data IN index
byte TXout = 0;                  // RS485 TX data OUT index
int1 gltmr3f    = 0;
int1 glprocessf = 0;
int1 gldata0f   = 0;
int1 gldata1f   = 0;
unsigned int8  siteCode    = 0;
unsigned int16 idCode      = 0;
unsigned int32 wiegandData = 0;
#int_ext    // Data0 external interrupt
void data0_isr()
   if (!gldata0f)
      wiegandData <<= 1;
   if (!gltmr3f){
      set_timer3(30536);
      clear_interrupt(int_timer3);
      enable_interrupts(int_timer3);
      gltmr3f = 1;
#int_ext1   // Data1 external interrupt
void data1_isr()
   if (!gldata1f){
      wiegandData <<= 1;
      wiegandData |= 1;
   if (!gltmr3f){
      set_timer3(30536);
      gltmr3f = 1;
#int_timer3 // 3mSec. timeout
void timer3_isr()
   disable_interrupts(int_timer3);
   glprocessf = 1;
   gldata0f = 1;
   gldata1f = 1;
#int_tbe
void Serial_TX_isr()
   putc(TXbuffer[TXout]);           // put char to TXbuffer then send
   TXout=(TXout+1) % TX_SIZE;       // increment & limit to max buffer size
   if(TXin==TXout)                  // if last in data, stop RS485 TX interrupt
     disable_interrupts(int_tbe);   // disable transmit interrupt
void bputc(char c)                  // bufferred putc routine
   short restart;                   // restart flag
   int ni;                          // temp variable
   restart=TXin==TXout;             // set restart flag at start
   TXbuffer[TXin]=c;                // store char to TXbuffer
   ni=(TXin+1) % TX_SIZE;           // limit to max buffer size
   while(ni==TXout);
   TXin=ni;
   if(restart)                      // enable TX interrupt
     enable_interrupts(int_tbe);
int1 check_Parity(unsigned int8 index,unsigned int32 wgCode)
   int1 pResult   =0;
   unsigned int8 i=0;
   for (i=index; i<index>>16) & 0xFF;
               printf(bputc,"\r\nSite Code = %U ** ID Code = %LU \r\n",siteCode,idCode);
               wiegandData = 0;
         gldata0f = 0;
         gldata1f = 0;
         gltmr3f = 0;
Enjoy... =P
Newbaby
PostPosted: Sat Aug 12, 2006 2:49 am     Reply with quote
Hi ChingB,
Could you put an example code to show how to use your driver please
chingB
Re: Wiegand to Serial Driver
PostPosted: Sun Aug 13, 2006 2:21 am     Reply with quote
Newbaby wrote:
Hi ChingB,
Below is the complete code listing:
int1 gltmr3f    = 0;
int1 gldata0f   = 0;
int1 gldata1f   = 0;
void data0_isr()
   if (!gldata0f)
      wiegandData <<= 1;
   if (!gltmr3f){
      set_timer3(30536);
      gltmr3f = 1;
void data1_isr()
   if (!gldata1f){
      wiegandData <<= 1;
      wiegandData |= 1;
   if (!gltmr3f){
      set_timer3(30536);
      gltmr3f = 1;
void timer3_isr()
   glprocessf = 1;
   gldata0f = 1;
   gldata1f = 1;
#int_tbe
   while(ni==TXout);
   TXin=ni;
I got a problem of posting the entire code. I'll post it on a separate reply for the example on how I use it.
chingB
PostPosted: Sun Aug 13, 2006 2:40 am     Reply with quote
Newbaby wrote:
Hi ChingB,
   int1 pResult   =0;
   unsigned int8 i=0;
   for (i=index; i<(index+13); i++)
      pResult ^= bit_test(wgCode,i);
   return(pResult);
chingB
PostPosted: Sun Aug 13, 2006 2:42 am     Reply with quote
Below is the listing for the Main Program
void init_mcu() // MCU Initialization Routine
   delay_ms(4000); // delay for 4 seconds (stabilized MCU?)
   // B0 & B1 are conficured as input
   // the reset of PortB I/O are set to output
   set_tris_b(0x03); // set PortB I/O directions
   ENABLE_PULLUPS(); // enable weak pullups for PortB[0..7]
   INTEDG0 = 0;      // set to falling edge (External-0 Interrupt)
   INT0IF  = 0;      // clear ext0 interrupt flag
   INTEDG1 = 0;      // set to falling edge (External-2 Interrupt)
   INT1IF  = 0;      // clear ext2 interrupt flag
   TMR3IF  = 0;   // clear timer3 Interrupt flag
   setup_adc_ports(NO_ANALOGS); // setup PortA to digital I/O
   setup_timer_3(T3_INTERNAL | T3_DIV_BY_8); // 104.8576mSec. timer overflow
   enable_interrupts(int_ext);
   enable_interrupts(int_ext1);
   enable_interrupts(global);   // enable global interrupt
// Main Program
main()
   init_mcu();                 // initialize MCU
   while (TRUE)
      if (glprocessf)
         glprocessf = 0;
         //printf("\r\nWiegand Data = %LX\r\n",wiegandData);
         if (check_Parity(0,wiegandData) == 1)        // odd parity
            if (check_Parity(13,wiegandData) == 0){   // even parity
               idCode = wiegandData & 0xFFFF;
               siteCode = (wiegandData>>16) & 0xFF;
               wiegandData = 0;
         gldata0f = 0;
         gldata1f = 0;
         gltmr3f = 0;
=P
jrgob
PostPosted: Fri Jul 01, 2011 8:36 am     Reply with quote
Hello ChingB...
I understand your software, the data is received for connverter wiegand protocol for serial ...
I have some questions:
1) It is a generic code, suitable for any pic?
2) The protocol format is receiving wiegand 26? or receive any wiegand format?
I need to make a protocol wiegand converter for RS232 ... I know if you can help me.
Thanks.
jrgob
cllunlu
PostPosted: Mon Jun 30, 2014 1:59 am     Reply with quote
I have project that reading data with wiegand 26 protocol. I am using PIC18F46K22 and CCS C. Compiler version 5.0.13.
I have used this code. But I failed. I wanna ask, why we use timer? Using external interrupt for Data0 and Data1 is not enough?
Can you please help about it?
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
