GhostofK Guest
| Left shift question |
Posted: Sun Jun 04, 2006 3:04 pm |
Hi, I'm working on a school project and I have another question about some code. I'm trying to do a left shift on a variable named 'mask'. If I write:
int16 mask = 1;
mask = mask << 1;
then will the result be mask = 10 or mask = 11?
The code that I'm using is right below as well.
void drive_led(int16 code){
int16 code_bit = 0x0000;
int16 mask = 0x0001;
delay_ms(20);
output_high(PIN_C1);
delay_ms(2400);
output_low(PIN_C1);
delay_ms(600);
while(mask != 0x1000){
code_bit = code && mask;
if(code_bit != mask){
delay_us(600);
output_low(PIN_C1);
delay_us(600);
else{
delay_us(1200);
output_low(PIN_C1);
delay_us(600);
mask = mask << 1;
Thanks for any help! |
newguy
Posted: Sun Jun 04, 2006 3:13 pm |
| After the shift operation mask will be 0x02 (binary 10). Shifts always shift in zeroes. |
Posted: Sun Jun 04, 2006 3:14 pm |
<<, is equivalent to multiplying by two. So binary 001, becomes '010'.
If you want to shift a value in, then look at the 'shift left' command. This allows a value to be shifted in to fill the bottom bit. So:
int16 value=0b0000000000000001;
shift_left(&value,2,0);
//This gives 0b0000000000000010;
shift_left(&value,2,1);
//This gives 0b0000000000000101;
So with this command, you can elect to shift in a zero or a one as required.
Look also at:
int16 value=0b1000000000000000;
rotate_left(&value,2);
//This gives 0b0000000000000001;
This form, rotates, rather than shifting the word, in the example, taking the top bit, and rotating it back to the bottom bit.
GhostofK Guest
Posted: Sun Jun 04, 2006 3:45 pm |
| Thanks for the help! |
GhostofK
Posted: Sun Jun 04, 2006 4:52 pm |
| Hi, I'm having some trouble with my code that I posted above originally. For some reason, pin C1 is not going all the way high. The timing is perfect, but pin_C1 is only going up to about 600mV instead of the full 5v as it should. Does anyone know what could be the problem here? |
