simon630
| can #undef, #define used in subroutine for memory addressing |
Posted: Fri Jul 04, 2003 4:36 am |
Hi, friends,
I am wondering whether these two pre-processor directives could be used in subroutine.
here is a sample programme.
#define SERIAL_NO 5
void routine1(){
if (a>5)
#undef SERIAL_NO
#define SERIAL_NO 10
void write_ram(){
//SERIAL_NO is used as the address of memory access
main(){
___________________________
Original Post ID: 144515735 |
neil
| Re: can #undef, #define used in subroutine for memory addres |
Posted: Fri Jul 04, 2003 6:22 am |
<font face="Courier New" size=-1>Hello, I'm not absolutely sure, but I think #define and #undef are just compiler directives which are evaluated by the compiler, not the PIC. If you try to use compiler directives at run time, I would expect the compiler to give an error.
If you want to store a nonvolatile serial number on a chip, but want to be able to change it, why not use a device with internal EČPROM such as 16Fxxx and put the serial no. in EČ
Regards,
Neil.
:=Hi, friends,
:= I am wondering whether these two pre-processor directives could be used in subroutine.
:= here is a sample programme.
:=#define SERIAL_NO 5
:=void routine1(){
:=if (a>5)
:=#undef SERIAL_NO
:=#define SERIAL_NO 10
:=void write_ram(){
:= //SERIAL_NO is used as the address of memory access
:=main(){
:=}</font>
Original Post ID: 144515738 |
