Lost RJ11 cable for my programmer; how can I replace?
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
Spasticteapot
PostPosted: Thu Feb 23, 2006 2:41 pm     Reply with quote
Having finally found an appropriate wall-wart for my development board, I found I'm missing the RJ-11 cable. I dug out a 4-wire cable used with a telephone, but it does'nt seem to work.
Can I get a six-wire RJ11 cable from radioshack, and will it work if it's straight-through? (I don't know if these use a crossover cable.)
PostPosted: Thu Feb 23, 2006 3:41 pm     Reply with quote
The 6-pin modular cable that comes with the Microchip ICD2 is the
reversed style. On one end, the colors are:
White
Black
Red
Green
Yellow
Blue
On the other end, the order is reversed.
iso9001
PostPosted: Fri Feb 24, 2006 1:00 pm     Reply with quote
Thats probably not really helpful to him.
I don't know where you are located but, Heres what I did (i live in the states)
Goto your local home depot, ACE, lowes, whatever hardware store and ask to buy some 6 wire phone cable, I like the flat stuff but CAT 3e or CAT5e will work too, acutally it'll work a tiny bit better but not enough you'de ever notice.
Now, while the guy is cutting it ask him if he'd mind crimping on some 6 contact RJ12/RJ11 connectors, forget the wire colors because they mean nothing. Just make sure they are the same when held directly to each other, or reversed when held next to one another.
If he doesn't want to crimp them on then I'de recommend buying the tool. It WILL come in handy at some point, not just with pic projects but around the house or for that cute neighbor girl too. My tool does RJ45 and RJ11, I think it set me back all of $20, pretty well made too.
These are non crossover.
edit: Oh and my cables are always a little over a foot and have never really had any problems. I'de stay at or under 12" tho
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
