dlc@frii.com
| disassembly listing is blank when I do this... |
Posted: Wed Feb 22, 2006 11:48 am |
While correcting some FUBARs in my ISR code noted by our astute crowd here, I found something interesting. My disassembly window goes blank when I add a couple of assembler instructions. The following code works as expected:
#int_global
void isr(void)
#asm
//store current state of processor
MOVWF save_w
SWAPF status,W
MOVWF save_status
BCF status,5 //Set to page 0 for SFR's
BCF status,6
#endasm
However, if I add the save_FSR code below, the disassembly listing goes away, which leaves me feeling uncomfortable:
#int_global
void isr(void)
#asm
MOVWF save_w
SWAPF status,W
MOVWF save_status
SWAPF FSR,W
MOVWF save_FSR
BCF status,6
#endasm
Does any CCS guru out there know what rule I just violated by doing this?
many thanks,
DLC _________________ --
Dennis Clark dlc@frii.com
http://www.techtoystoday.com
Posted: Wed Feb 22, 2006 1:17 pm |
I can't compile your code as posted. It gets errors.
Can you add the missing items, so it can be compiled ? |
Posted: Wed Feb 22, 2006 7:01 pm |
| PCM programmer wrote: | I can't compile your code as posted. It gets errors.
Sure, you will recognize it I'll bet...
thanks,
DLC
#include <16F628.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,NOLVP,NOCPD,NOBROWNOUT,MCLR
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1)
#use fast_io(A)
#use fast_io(B)
#define MAXBIT 13 //5 address, 7 control and one junk timing
int rise[MAXBIT];
int rW=0;
int gotOne = 0;
//save_w and save_status are at 7f and 7e which are available in ALL banks
int save_w;
#locate save_w=0x7f
int save_status;
#locate save_status=0x7e
int save_FSR;
#locate save_FSR=0x7d
#byte FSR = 4
#byte status = 3
#byte TMR1L = 0x0E
#byte TMR1H = 0x0F
#byte PIR1 = 0x0C
#byte CCPR1H = 0x16
#int_global
void isr(void)
#asm
MOVWF save_w
SWAPF status,W
MOVWF save_status
SWAPF FSR,W
MOVWF save_FSR
BCF status,6
#endasm
rise[rW++] = CCPR1H; //save the pulse time
if (rW == MAXBIT)
rW = 0;
gotOne = 1;
TMR1L = 0;
TMR1H = 0;
#asm
// restore processor and return from interrupt
SWAPF save_FSR,W
MOVWF FSR
SWAPF save_status,W
MOVWF status
SWAPF save_w,F
SWAPF save_w,W
BCF PIR1,2
#endasm
int x;
int n=0;
set_tris_B(0x03);
set_tris_A(0x00);
//Turn off comparator
setup_ccp1(CCP_CAPTURE_FE); // Configure CCP1 to capture falling edge detection
setup_timer_1(T1_INTERNAL); // Start timer 1
for (x=0;x<MAXBIT;x++)
rise[x]=0;
enable_interrupts(INT_CCP1); // Setup interrupt on falling edge
printf("SONY IR decoder\n\r");
if (n)
output_low(PIN_A1);
n=0;
output_high(PIN_A1);
n=1;
if (gotOne)
gotOne = 0;
printf("\n\r%u %u counts ",x, rise[x]);
Posted: Wed Feb 22, 2006 7:16 pm |
| Quote: | | My disassembly window goes blank when I add a couple of assembler instructions. |
I'm not sure what you mean by 'blank'. Do you mean that you see
nothing at all, or that just the #int_global routine is missing ?
I compiled your program with PCM vs. 3.242 and MPLAB vs. 7.20.
Here is the code viewed from "View / Disassembly Listing" in MPLAB:
| Code: | 28: #int_global
29: void isr(void)
30: {
31: #asm
32: //store current state of processor
33: MOVWF save_w
0004 00FF MOVWF 0x7f
34: SWAPF status,W
0005 0E03 SWAPF 0x3, W
35: MOVWF save_status
0006 00FE MOVWF 0x7e
36: SWAPF FSR,W
0007 0E04 SWAPF 0x4, W
37: MOVWF save_FSR
0008 00FD MOVWF 0x7d
38: BCF status,5 //Set to page 0 for SFR's
0009 1283 BCF 0x3, 0x5
39: BCF status,6
000A 1303 BCF 0x3, 0x6
40: #endasm |
The .LST file also looks OK:
0000 00372 .................... #int_global
0000 00373 .................... void isr(void)
0000 00374 .................... {
0000 00375 .................... #asm
0000 00376 ..... //store current state of processor
0000 00377 .................... MOVWF save_w
0004 00FF 00378 MOVWF 7F
0000 00379 .................... SWAPF status,W
0005 0E03 00380 SWAPF 03,W
0000 00381 .................... MOVWF save_status
0006 00FE 00382 MOVWF 7E
0000 00383 .................... SWAPF FSR,W
0007 0E04 00384 SWAPF 04,W
0000 00385 .................... MOVWF save_FSR
0008 00FD 00386 MOVWF 7D
0000 00387 .................... BCF status,5 //Set to page 0 for SFR's
0009 1283 00388 BCF 03.5
0000 00389 .................... BCF status,6
000A 1303 00390 BCF 03.6
0000 00391 .................... #endasm |
Posted: Thu Feb 23, 2006 10:25 am |
| PCM programmer wrote: | | Quote: | | My disassembly window goes blank when I add a couple of assembler instructions. |
I'm using 3.242 and MPLAB 7.01. When I pull up the view->disassembly listing I have a blank window. If I leave those offending lines out I have the usual disassembly listing. I note that the .lst file is there also.
DLC |
Posted: Thu Feb 23, 2006 10:55 am |
| I recommend that you upgrade to the latest version of MPLAB. |
Posted: Thu Feb 23, 2006 1:16 pm |
| PCM programmer wrote: | | I recommend that you upgrade to the latest version of MPLAB. |
I just upgraded to MPLAB 7.20 (I already have PCM 3.242) and I get the same results as before.
There must be something else that is causing this problem.
DLC |
dlc Guest
Posted: Mon Feb 27, 2006 1:18 pm |
| Anonymous wrote: | | PCM programmer wrote: | | I recommend that you upgrade to the latest version of MPLAB. |
DLC |
When I added other code in the ISR my dissassembly view magically re-appeared. It appears that there is some kind of bug in MPLAB. ;) Regardless, the code compiles and runs properly regardless of the MPLAB oddity.
thanks all,
DLC |
