source code of 4x4 keypad
ssssss
PostPosted: Thu Jan 26, 2006 8:57 pm     Reply with quote
hi
i want source code of 4x4 keypad interface by C language using pic 16f877.
thanks for any help. Exclamation Exclamation Exclamation Exclamation
PostPosted: Thu Jan 26, 2006 9:28 pm     Reply with quote
Try searching this board for 4x4 and you will find lots of help!
sk
Don't re-invent the wheel...
PostPosted: Fri Jan 27, 2006 2:11 am     Reply with quote
Re-use the keyboard driver found the driver section provided with CCS PICC compiler.All you need to do is to add the forth columnplus some few lines on the code
