Global Variable vrs Local function variable
steve byrne
PostPosted: Tue Jun 17, 2003 7:55 pm     Reply with quote
Hello Im trying to figure out why the compiler barfs on the code
below if I use byte BUFFER [2]; in the actual read_shiftregister
function as opposed to using it globally as shown. Im using ver 3.112 of the compiler
Any insight would be helpful.
Thanx Steve.
#include <16f84.h>
#use fast_io(A)
#define ENABLE PIN_A1
#define CLOCK PIN_A2
#define DATA_IN PIN_A3
#define Loop while (1)
byte BUFFER [2]; // Global Variable
void read_shiftregister(){
int16 count;
output_high(CLOCK);
output_low(ENABLE);
output_high(ENABLE);
for(count=1; count<=16; ++count) {
shift_left(BUFFER, 2 ,input (DATA_IN));
output_low(CLOCK);
output_high(CLOCK);
output_low(ENABLE);
void main(){
set_tris_a(0b00100);
loop;
read_shiftregister();
___________________________
Original Post ID: 144515341
Neutone
Re: Global Variable vrs Local function variable
PostPosted: Wed Jun 18, 2003 8:04 am     Reply with quote
Try something like this.
This code is for the ADC2402
Read ADC
OUTPUT_LOW(PIN_A3); //ADC CS low to verify reading is ready
if (!input(PIN_A2)) //ADC SDO low = sample ready
ADCreading = 0;
OUTPUT_HIGH(PIN_A1);
OUTPUT_LOW(PIN_A1);
Channel = input(PIN_A2); // read input channel
OUTPUT_LOW(PIN_A1);
OUTPUT_LOW(PIN_A1);
for (x= 1; x<= 24; x++)
OUTPUT_LOW(PIN_A1);
shift_left(&ADCreading,4,input(PIN_A2));
OUTPUT_HIGH(PIN_A3);
if (Channel) ADCreading1= ADCreading;
else ADCreading0 = ADCreading;
OUTPUT_HIGH(PIN_A3); //ADC CS high to begin new reading
Original Post ID: 144515353
