I have problems whit timer2 on Pic 16f876
LLuis Miquel Condom
PostPosted: Sat Jun 14, 2003 12:12 pm     Reply with quote
Using this configuration does not work. what is the problem???
#include "16f876.h"
#fuses HS, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
#use delay(clock=3276800)
//#use Delay(Clock=8000000)
#zero_ram
int_tmr2();
main()
setup_timer_2(T2_DIV_BY_16,0x7d,10);
set_tris_c(0);
set_timer2(22);
#INT_TIMER2
int_tmr2()
output_high(pin_c3); // Create a positive pulse on PIN A3.
output_low(pin_c3);
thanks
___________________________
Original Post ID: 144515241
Kenny
Re: I have problems whit timer2 on Pic 16f876
PostPosted: Sat Jun 14, 2003 4:14 pm     Reply with quote
:=Using this configuration does not work. what is the problem???
:=#include "16f876.h"
:=#fuses HS, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
:=#use delay(clock=3276800)
:=//#use Delay(Clock=8000000)
:=#zero_ram
:=int_tmr2();
:=main()
:=setup_timer_2(T2_DIV_BY_16,0x7d,10);
:=set_tris_c(0);
:=enable_interrupts(INT_TIMER2);
:=enable_interrupts(GLOBAL);
:=set_timer2(22);
:=while(1);
:=#INT_TIMER2
:=int_tmr2()
:=output_high(pin_c3); // Create a positive pulse on PIN A3.
:=output_low(pin_c3);
:=thanks
Should work.
set_timer2(22) will do nothing.
Code will give a pulse of around 2uS on C3 (not A3) every 10mS with 8MHz crystal.
Timer2 will interrupt every 0.5*16*125*10 = 10mS
Regards
Kenny
Original Post ID: 144515242
