Why isn't port D working on PIC16F877
MOLLY
PostPosted: Mon May 19, 2003 7:21 pm     Reply with quote
Hello, im just doing an easy test with
Output_high(PIN_D0) and so on. But port D is not responding. No change in voltage level!
What have I missed?
Thanks for any reply
Michael
___________________________
Original Post ID: 144514566
Dave Yeatman
Re: Why isn't port D working on PIC16F877
PostPosted: Mon May 19, 2003 9:54 pm     Reply with quote
How are you setting up the Port pins. Can you show us the initialization section of the program?? If it is short then post the whole thing otherwise we would be just wildly guessing,.... :-)
:=Hello, im just doing an easy test with
:=Output_high(PIN_D0) and so on. But port D is not responding. No change in voltage level!
:=What have I missed?
:=Thanks for any reply
:=Michael
Original Post ID: 144514567
MOLLY
JUST USING OUTPUT_HIGH.......
PostPosted: Mon May 19, 2003 10:07 pm     Reply with quote
I'm not setting up any ports, just using output_high(PIN_D0) and output_low(PIN_D0), this works just fine with all other ports, it's just port D that is not responding
Thank you again!
Original Post ID: 144514569
allen_m
PostPosted: Wed May 21, 2003 1:21 pm     Reply with quote
Hi Molly,
Check how you are setting PortE TRISE register ... if you inadvertantly set bit 4 of the TRISE register, Port D goes into PSP mode and will not respond to output_Hi/lo() calls.
Also try external pullups on Port D (perhaps not strictly required).
Allen M.
Original Post ID: 144514643
Bjorn Peschl
PostPosted: Thu May 22, 2003 7:42 am     Reply with quote
:=Michael
Are you sure that it isnīt a hardware problem?
If you have include the "standard 16F877.h" file, the following program should work...
# include "16F877.h"
# use delay (clock=4000000)
int i =0;
main ()
Loop:
for (i=1;i<=5;++i)
output_high( PIN_D0 );
delay_ms( 100 );
output_low( PIN_D0 );
delay_ms( 100 );
for (i=1;i<=5;++i)
output_high( PIN_D1 );
delay_ms( 100 );
output_low( PIN_D1 );
delay_ms( 100 );
Goto Loop;
Original Post ID: 144514672
John Taylor
Re: JUST USING OUTPUT_HIGH.......
PostPosted: Sat May 24, 2003 11:13 am     Reply with quote
Be sure this is included in the code:
setup_psp(PSP_DISABLED);
This will ensure that the PSP (Port D) in in I/O mode, not PSP.
Also, if you are using fast I/O, the port will be all inputs.
jt
:=I'm not setting up any ports, just using output_high(PIN_D0) and output_low(PIN_D0), this works just fine with all other ports, it's just port D that is not responding
:=Thank you again!
Original Post ID: 144514725
