Timers on the PIC
Kevin Mayer
Timers on the PIC
PostPosted: Mon Dec 03, 2001 5:47 pm     Reply with quote
Alright - I'm getting the hang of things now - but I'm not 100\% sure about the timer operations.
- Is it correct to say that all the timers (I'm using the PIC16F877) tick once over (4/clock rate) seconds? (if so, why '4'?)
- What is the deal with internal or external clock (eg., T1_INTERNAL, T1_EXTERNAL, T1_EXTERNAL_SYNC) - do the timers not necessarily go off the clock input I have hooked up to the chip?
Cheers :-)
Kevin
___________________________
Original Post ID: 1438
ajt
Re: Timers on the PIC
PostPosted: Mon Dec 03, 2001 10:12 pm     Reply with quote
:=Alright - I'm getting the hang of things now - but I'm not 100\% sure about the timer operations.
:=- Is it correct to say that all the timers (I'm using the PIC16F877) tick once over (4/clock rate) seconds? (if so, why '4'?)
Yes, unless you use a prescaler or postscaler. The reason for 4 is that the processor executes an instruction in one CPU cycle (except jumps which take 2 cycles) and 1 cycle of the CPU takes four oscillator clock ticks. The Timers "clock" on instruction cycles.
:=- What is the deal with internal or external clock (eg., T1_INTERNAL, T1_EXTERNAL, T1_EXTERNAL_SYNC) - do the timers not necessarily go off the clock input I have hooked up to the chip?
Timer0 and Timer1 can be clocked from an external source using a PORTA or PORTC pin, respectively.
:=Cheers <img src="http://www.ccsinfo.com/pix/forum/disagree.gif" border="0">)
:=Kevin
Original Post ID: 1441
Al Testani
Kevin Mayer
PostPosted: Mon Dec 03, 2001 10:27 pm     Reply with quote
Original Post ID: 1443
