rs232 string receive an compare problem
magic
PostPosted: Fri Apr 25, 2003 9:04 am     Reply with quote
<font face="Courier New" size=-1>following code sometimes bad working without "rs232 enable and disable lines"..i could not find Where is the problem.
problem is;
code passing from if line to bottom even you entered a invalid code!!!
i changed baudrate (to more speed or slow) but not solved.
would you suggest any more stable code about this task.
Regards.
char a[10];//="ab";
char b[10]="give";
char a[10]="";
printf("please enter your code: \n\r");
delay_ms(50);
bit_set(*0x18,4); //bit_set( RCSTA, SPEN );rs232 recieve enable
gets(a);
delay_ms(50);
bit_clear(*0x18,4);//rs232 recieve disable
if(!stricmp(a,b))// if result is zero entered code is "give".
</font>
___________________________
Original Post ID: 13993
Re: rs232 string receive an compare problem
PostPosted: Fri Apr 25, 2003 11:28 am     Reply with quote
:=problem is;
:=code passing from if line to bottom even you entered a invalid code!!!
:=i changed baudrate (to more speed or slow) but not solved.
I didn't have that problem. It appears to work OK
after I made it into a compilable program, below.
However, there are still some major design problems
with your code. One problem is that the gets() function
does not have any limit on the number of characters
that can be entered. If you do a Google search on gets(),
you will read comments like this:
"The gets function is known to be a security risk. This is
because the length of an input line can overflow the size
of the buffer, resulting in indeterminate behavior.."
<a href="http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dnucmg/html/UCMGch08.asp" TARGET="_blank">http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dnucmg/html/UCMGch08.asp</a>
"Gets()-- The Devil's Function"
<a href="http://www.accu.org/acornsig/public/caugers/volume2/issue4/gets.html" TARGET="_blank">http://www.accu.org/acornsig/public/caugers/volume2/issue4/gets.html</a>
etc.
So I suggest you use the get_string() function which is
provided by CCS in their INPUT.C file. This file is here:
c:\Program Files\Picc\Drivers
It's also available online here:
<a href="http://ms-n.org/DataSheets/ccs/examples/INPUT.C" TARGET="_blank">http://ms-n.org/DataSheets/ccs/examples/INPUT.C</a>
Also, there's another problem in your code. According to
the .LST file, when you declare char a[10]="";
inside the while() loop, you are creating another instance
of a. The .LST file refers to them as "a" and "main.a".
They are allocated at different ram addresses.
Your code still works, it just wastes ram.
<PRE>
#include <16F877.H>
#fuses HS, NOWDT, NOPROTECT, BROWNOUT, NOLVP, PUT
#use delay(clock = 8000000)
#use rs232(baud = 9600, xmit=PIN_C6, rcv = PIN_C7, ERRORS)
<BR>
#include <string.h>
<BR>
char a[10]; //="ab";
char b[10]= "give";
<BR>
char a[10]="";
delay_ms(50);
<BR>
gets(a);
delay_ms(50);
<BR>
printf("Good code\n\r");
printf("Bad code\n\r");
<BR>
</PRE>
Original Post ID: 13996
