Configuring I2C Routine for EEPROM IC (24xx00)
liche
PostPosted: Thu Apr 24, 2003 9:06 am     Reply with quote
Just some simple questions regarding the interface from a PIC16C66 to a 24xx00 EEPROM via I2C.
1. Is the following statement correct regarding proper set-up?
#USE I2C (master, SDA=PIN_B2, SCL=PIN_B3)
The 24xx00 does have a slave address of (1010). Do I need to use this address in the above statement???
2. I noticed in some examples such as:
i2c_start();
i2c_write(0xa0); //address
i2c_write(0x55); //data
i2c_stop();
that there seems to be no provision regarding the sending of a control byte. Is this done internally, or do I need to provide this control byte as well???
For example, for the 24xx00 EEPROM, the control byte looks like:
S 1 0 1 0 X X X
Where s=start bit, Device Select bit is 1010, and the last three bits are don't care.
Any help appreciated.
Liche
___________________________
Original Post ID: 13973
Re: Configuring I2C Routine for EEPROM IC (24xx00)
PostPosted: Thu Apr 24, 2003 11:19 am     Reply with quote
:=Just some simple questions regarding the interface from a PIC16C66 to a 24xx00 EEPROM via I2C.
:=1. Is the following statement correct regarding proper set-up?
:=#USE I2C (master, SDA=PIN_B2, SCL=PIN_B3)
Yes, this is OK.
:=The 24xx00 does have a slave address of (1010). Do I need to use this address in the above statement???
No.
:=2. I noticed in some examples such as:
:=i2c_start();
:=i2c_write(0xa0); //address
:=i2c_write(0x55); //data
:=i2c_stop();
:=that there seems to be no provision regarding the sending of a control byte. Is this done internally, or do I need to provide this control byte as well???
The "0xa0" is the control byte.
Use 0xa0 for a write operation and 0xa1 for a read operation.
Here is a CCS example file for the 2402 eeprom:
<a href="http://ms-n.org/DataSheets/ccs/examples/2402.C" TARGET="_blank">http://ms-n.org/DataSheets/ccs/examples/2402.C</a>
You can look at each line in the example program, and compare
it to the diagrams shown in the data sheet. Also, be sure
to note that the last read operation requires a NACK, which
is done by using a 0 parameter with the i2c_read() function.
You can see this in Figure 8-1 of the data sheet, where it
says "NO ACK". Use "i2c_read(0)" to do that.
Also, notice the "delay_ms(11)" statement at the end of
a write function. That delay allows time for the eeprom to
do the physical write operation.
Here is the data sheet:
<a href="http://www.microchip.com/download/lit/pline/memory/ic/21178c.pdf" TARGET="_blank">http://www.microchip.com/download/lit/pline/memory/ic/21178c.pdf</a>
Original Post ID: 13978
