j@qmail.com Guest
| rs232 fprintf pacing question |
Posted: Sat Apr 12, 2003 6:19 pm |
Does anyone know how ccs paces rs232 output (with and without USART)? For example, suppose I fprintf ten characters to a stream. Do I get control back immediately or do I have to wait for the characters to be transmitted?
If I get control back immediately, what happens if I send another ten characters?
(It seems to me that there should be a "ready" bit somewhere to test but I haven't found it in the docs I have.)
Tnx,
Jay
___________________________
Original Post ID: 13633 |
| Re: rs232 fprintf pacing question |
Posted: Sat Apr 12, 2003 10:42 pm |
:=Does anyone know how ccs paces rs232 output (with and without USART)? For example, suppose I fprintf ten characters to a stream. Do I get control back immediately or do I have to wait for the characters to be transmitted?
:=If I get control back immediately, what happens if I send another ten characters?
:=(It seems to me that there should be a "ready" bit somewhere to test but I haven't found it in the docs I have.)
You're asking if fprintf() has a software transmit fifo.
It doesn't. So, yes, you'll have to wait until most of
the characters are transmitted.
If you want a transmit buffer, you have to add the code for it.
CCS has an example file for this, called EX_STISR.C.
It's in this folder: c:\Program Files\Picc\Examples
The same thing is true for a receive fifo. You have to code it.
See EX_SISR.C for an example. It's in the same folder.
Original Post ID: 13634 |
j@qmail.com Guest
Posted: Sun Apr 13, 2003 9:46 pm |
:=You're asking if fprintf() has a software transmit fifo.
:=It doesn't. So, yes, you'll have to wait until most of
:=the characters are transmitted.
Thanks,
Jay
Original Post ID: 13645 |
