delay_us( B * {period})
Joe Heinrich
PostPosted: Mon Nov 26, 2001 1:14 pm     Reply with quote
For a situation like below,
for (...)
some lines of code...
specific event_D
delay_us( A - B*C);
some more lines of code..
A = known amount of time, say 60 us.
B = total_clks(for some lines of code) ie a number that I manually put in.
C = Period (which is my osc/8)
Is there a way to 'call-in' the period. So that later on, should I decide to use a different value in the #use delay() that the delay will be calculated right? I want to do this because I want to keep the time between 'specific event_d' constant.
Joe
___________________________
Original Post ID: 1324
Tomi
Re: delay_us( B * {period})
PostPosted: Tue Nov 27, 2001 11:10 am     Reply with quote
Maybe you are about "calculated delay". You can enter a 8-bit variable for the delay_us() and delay_ms() functions (16-bit integers are supported only as const). So you can use something like this:
char i,myvar;
i = 10;
myvar = 60 - 2*i;
delay_us(myvar);
:=For a situation like below,
:=for (...)
:=some lines of code...
:=specific event_D
:=delay_us( A - B*C);
:=some more lines of code..
:=A = known amount of time, say 60 us.
:=B = total_clks(for some lines of code) ie a number that I manually put in.
:=C = Period (which is my osc/8)
:=Is there a way to 'call-in' the period. So that later on, should I decide to use a different value in the #use delay() that the delay will be calculated right? I want to do this because I want to keep the time between 'specific event_d' constant.
:=Joe
Original Post ID: 1341
Joe Heinrich
PostPosted: Tue Nov 27, 2001 11:45 am     Reply with quote
that is closer to what I want. Can I do something like this?
#define freq = 2457600;
#use_delay(freq);
float i; // WILL this work?
i = 1/(freq/8);
myvar = 60 - 2 *i;
Joe
:=Maybe you are about "calculated delay". You can enter a 8-bit variable for the delay_us() and delay_ms() functions (16-bit integers are supported only as const). So you can use something like this:
:=char i,myvar;
:=i = 10;
:=myvar = 60 - 2*i;
:=delay_us(myvar);
:=:=For a situation like below,
:=:=for (...)
:=:=some lines of code...
:=:=specific event_D
:=:=delay_us( A - B*C);
:=:=some more lines of code..
:=:=A = known amount of time, say 60 us.
:=:=B = total_clks(for some lines of code) ie a number that I manually put in.
:=:=C = Period (which is my osc/8)
:=:=Is there a way to 'call-in' the period. So that later on, should I decide to use a different value in the #use delay() that the delay will be calculated right? I want to do this because I want to keep the time between 'specific event_d' constant.
:=:=Joe
Original Post ID: 1342
Tomi
PostPosted: Tue Nov 27, 2001 12:07 pm     Reply with quote
No. Keep in mind that the arithmetic calculation needs time.
The floating point calculation needs lot of time. You can make 255usec max. with delay_us(var) and your floating point calc. needs approx. 1-2 msec.
Plus you have some syntax errors. Correct:
#define freq 2457600 // no semicolon. It is a #define statment
#use delay(freq) // no semicolon. It is a compiler statement
If I strongly understand your expression "1/(freq/8)" is constant.
However, if you want to use calculated delay then it would be better to use a simple integer arithmetics, e.g.:
The "8/freq" is 3.2552 usec. For more prec. use a 16-bit variable what is 256*(8/freq) what is 833. Use a simple calculation, then use the HIGH byte of the result as input parameter for the delay_us() call (this is the "value/256"), e.g.:
int16 myvar,inttime;
#byte myvarH = myvar+1
inttime = 833;
myvar = 15360 - 2 *inttime; // 15360 = 60*256
delay_us(myvarH);
:=that is closer to what I want. Can I do something like this?
:=#define freq = 2457600;
:=#use_delay(freq);
:=float i; // WILL this work?
:=i = 1/(freq/8);
:=myvar = 60 - 2 *i;
:=Joe
:=:=Maybe you are about "calculated delay". You can enter a 8-bit variable for the delay_us() and delay_ms() functions (16-bit integers are supported only as const). So you can use something like this:
:=:=char i,myvar;
:=:=i = 10;
:=:=myvar = 60 - 2*i;
:=:=delay_us(myvar);
:=:=:=For a situation like below,
:=:=:=for (...)
:=:=:=some lines of code...
:=:=:=specific event_D
:=:=:=delay_us( A - B*C);
:=:=:=some more lines of code..
:=:=:=A = known amount of time, say 60 us.
:=:=:=B = total_clks(for some lines of code) ie a number that I manually put in.
:=:=:=C = Period (which is my osc/8)
:=:=:=Is there a way to 'call-in' the period. So that later on, should I decide to use a different value in the #use delay() that the delay will be calculated right? I want to do this because I want to keep the time between 'specific event_d' constant.
:=:=:=Joe
Original Post ID: 1344
Joe Heinrich
PostPosted: Tue Nov 27, 2001 1:26 pm     Reply with quote
What I intended is for 'myvar' to be a constant value for a given oscialator. And I see making 'i' an variable is not what I meant to do. The only time I would ever want 'myvar' to change would be when I enter a different osciallator value. So 'myvar' would be calculated at compile time ONLY. (For this intended use.)
But you have brought to my attention the fact that the delay_us() can have a variable value to it. A feature I was not aware of... Thanks.
:=No. Keep in mind that the arithmetic calculation needs time.
:=The floating point calculation needs lot of time. You can make 255usec max. with delay_us(var) and your floating point calc. needs approx. 1-2 msec.
:=Plus you have some syntax errors. Correct:
:=#define freq 2457600 // no semicolon. It is a #define statment
:=#use delay(freq) // no semicolon. It is a compiler statement
:=If I strongly understand your expression "1/(freq/8)" is constant.
:=However, if you want to use calculated delay then it would be better to use a simple integer arithmetics, e.g.:
:=The "8/freq" is 3.2552 usec. For more prec. use a 16-bit variable what is 256*(8/freq) what is 833. Use a simple calculation, then use the HIGH byte of the result as input parameter for the delay_us() call (this is the "value/256"), e.g.:
:=int16 myvar,inttime;
:=#byte myvarH = myvar+1
:=inttime = 833;
:=myvar = 15360 - 2 *inttime; // 15360 = 60*256
:=delay_us(myvarH);
:=:=that is closer to what I want. Can I do something like this?
:=:=#define freq = 2457600;
:=:=#use_delay(freq);
:=:=float i; // WILL this work?
:=:=i = 1/(freq/8);
:=:=myvar = 60 - 2 *i;
:=:=Joe
:=:=:=Maybe you are about "calculated delay". You can enter a 8-bit variable for the delay_us() and delay_ms() functions (16-bit integers are supported only as const). So you can use something like this:
:=:=:=char i,myvar;
:=:=:=i = 10;
:=:=:=myvar = 60 - 2*i;
:=:=:=delay_us(myvar);
:=:=:=:=For a situation like below,
:=:=:=:=for (...)
:=:=:=:=some lines of code...
:=:=:=:=specific event_D
:=:=:=:=delay_us( A - B*C);
:=:=:=:=some more lines of code..
:=:=:=:=A = known amount of time, say 60 us.
:=:=:=:=B = total_clks(for some lines of code) ie a number that I manually put in.
:=:=:=:=C = Period (which is my osc/8)
:=:=:=:=Is there a way to 'call-in' the period. So that later on, should I decide to use a different value in the #use delay() that the delay will be calculated right? I want to do this because I want to keep the time between 'specific event_d' constant.
:=:=:=:=Joe
Original Post ID: 1345
