Kristian Guest
| Pic16f877 and internal ADC convertion |
Posted: Thu Mar 27, 2003 4:29 pm |
Hello, I'm having truble with the ADC convertion on the pic. So I was wondering if anybody could help me with the code in C for the init, input, convertion and yes almost everything. How should I couple the pic, and what ref on wich pin should I use.
Need HELP
Kristian
___________________________
Original Post ID: 13161 |
| Re: Pic16f877 and internal ADC convertion |
Posted: Thu Mar 27, 2003 4:48 pm |
:=Hello, I'm having truble with the ADC convertion on the pic. So I was wondering if anybody could help me with the code in C for the init, input, convertion and yes almost everything. How should I couple the pic, and what ref on wich pin should I use.
See the CCS example file, EX_ADMM.C, which is in this folder:
c:\Program Files\Picc\Examples
The only lines you need to change are these:
<PRE>
#include <16c74.h>
#fuses HS,NOWDT,NOPROTECT
</PRE>
Change them to be:
<PRE>
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT,NOLVP
</PRE>
If your crystal frequency is 4 MHz, then change the HS to XT.
I also assume your PIC is using a +5 volt power supply.
Connect the center pin of a trimpot (1K will work) to pin 2
of the 40-pin 16F877. Connect one end of the trimpot to +5v,
and the other end to Ground.
The example file uses the internal voltage reference of +5v.
Original Post ID: 13162 |
Kristian Guest
| Thank you but.. |
Posted: Thu Mar 27, 2003 7:52 pm |
I'm using a 11MHz crystal, should i use a 4mhz? And should I use the setup_adc(ADC_CLOCK_DIV_32)?
I'm measuring the heart beat , so is the 4MHz fast enough?
What is best to use then XT or HS
Thank you so much
Original Post ID: 13165 |
| Re: Thank you but.. |
Posted: Thu Mar 27, 2003 8:39 pm |
:=I'm using a 11MHz crystal, should i use a 4mhz? And should I use the setup_adc(ADC_CLOCK_DIV_32)?
:=I'm measuring the heart beat , so is the 4MHz fast enough?
:=What is best to use then XT or HS
The data sheet says that the internal A/D clock should
only be used in sleep mode, if the PIC's clock is greater
than 1 MHz.
So, in your case, you should use ADC_CLOCK_DIV_32. The chart
in section 11.2 of the data sheet shows that this is the
correct value for an 11 MHz crystal.
If you look at Table 12-2 in the data sheet, it shows that HS
is recommended for an 11 MHz crystal. You may need a series
resistor in the oscillator circuit, as shown in Figure 12-1.
I use 470 ohms.
The heart beat is about 1-2 Hz. So a 4 MHz crystal would
certainly provide enough processing power to handle such
a low data rate.
You may want to use an external circuit to do some signal
conditioning (ie., op-amp circuits) and use the CCP to measure
the heartbeat frequency. Just a suggestion -- you can always
do it at a later date.
The data sheet can be downloaded here:
<a href="http://www.microchip.com/1000/pline/picmicro/category/flash/index.htm" TARGET="_blank">http://www.microchip.com/1000/pline/picmicro/category/flash/index.htm</a>
Reference manuals, with more information than the data sheet,
<a href="http://www.microchip.com/1000/suppdoc/refernce/midrange/index.htm" TARGET="_blank">http://www.microchip.com/1000/suppdoc/refernce/midrange/index.htm</a>
Original Post ID: 13166 |
Kristian Guest
| Than you once again, just one more question.. |
Posted: Thu Mar 27, 2003 9:19 pm |
Everything works great now, the only thing is that when I massure, the readings change from hex 3F6 to hex 3FE when Im putting steady 5V trough the AD port. Is there any way I can make this go away. And Is it possible to just massure from 0 to 2,5 V and get the full resulution ( 0 to 3ff) The signals im getting is very small and i need the highest accuracy possible
Thank you so much!
Original Post ID: 13172 |
| Re: Than you once again, just one more question.. |
Posted: Fri Mar 28, 2003 12:34 pm |
:=Everything works great now, the only thing is that when I massure, the readings change from hex 3F6 to hex 3FE when Im putting steady 5V trough the AD port. Is there any way I can make this go away. And Is it possible to just massure from 0 to 2,5 V and get the full resulution ( 0 to 3ff) The signals im getting is very small and i need the highest accuracy possible
Microchip recommends that you put a small capacitor on the
A/D input pin. I would start with .01 uf. See if that fixes
the problem.
If you look in the 16F877.H file, you will see a list of all
the constants that are used to define the A/D pins setup.
Here is one that looks suitable:
#define RA0_RA1_ANALOG_RA3_REF 0x85 // A0 A1 Ref=A3
That one would allow using RA0 and RA1 as A/D inputs. It uses
RA3 as the Vref input pin. So the line of code would be:
setup_adc_ports(RA0_RA1_ANALOG_RA3_REF);
Then you could put 2.5v on the pin A3, as the reference voltage.
Original Post ID: 13208 |
