Question about 18F series (18F252)
Pete Smith
PostPosted: Mon Mar 24, 2003 1:59 pm     Reply with quote
Hi all.
I'm thinking of upgrading my compiler to PCH, so I can use 18F parts (specifically 18F252, because it's pin compatible with the 16F876A we use at present - hopefully I can track down some 18LF parts eventually).
I see the 252 has 1536 bytes of RAM.
How is this accessed? In the 16 series, it's limited to 96 bytes per array (due to the register layout). As far as I can tell, looking at the data sheet, the 18F252, the user RAM is from locations 0x0018-0x7fff.
Is this a totally different way of looking at a PIC, rather than having a limited set of registers, actually having RAM as such?
Does this mean I could actually define an array of 1024 bytes, and it all work?
Many thanks,
Pete.
___________________________
Original Post ID: 13020
Tomi
Re: Question about 18F series (18F252)
PostPosted: Tue Mar 25, 2003 1:14 am     Reply with quote
Yes. For example I have a declaration of:
char MMCPuffer[512];
and it works fine :)
:=Does this mean I could actually define an array of 1024 bytes, and it all work?
Original Post ID: 13039
Pete Smith
PostPosted: Tue Mar 25, 2003 1:57 am     Reply with quote
:=Yes. For example I have a declaration of:
:=char MMCPuffer[512];
:=and it works fine
That's great.
Now all I need to do is scrape up enough to get the compiler - or get work to buy it for me!
Thanks,
Pete.
Original Post ID: 13040
