#org has no effect
Goto page Previous  1, 2
kypec
Re: just curious about undocumented directives
PostPosted: Fri Jul 02, 2004 2:29 am     Reply with quote
1) The boot vector (#build allows this to be relocated).
2) The interrupt vector (#interrupt allows this to be relocated).
3) The 'delay' code.
4) The RS232 handler code.
The 'key' is that the last two, are actually placed in the bottom of memory _before_ the #org is met. The CCS compiler, does not recursively apply it's directives (which can be 'useful', allowing multiple #delay statements etc.). In this case, it means that code has allready been written into the area concerned.
You can relocate (for example) the 'delay' code, by adding an 'org' in front of this, and this would potentially allow the problem to be fixed.
Is there any chance to relocate HIGH and LOW priority interrupts
individually on 18F parts?
I mean that #interrupt directive allows you to relocate standard
interrupt vector at ROM address 0x0008.
But what should I do if I want to relocate also the vector at ROM address 0x0018?
TIA
kypec
object01
Re: #org has no effect
PostPosted: Fri Jul 02, 2004 10:59 am     Reply with quote
Ttelmah wrote:
I'd compile the program without any memory reserved. Look in the produced symbol map for the value assined to 'main', and place the block there. This will be the lowest address 'above' this stuff.
You can use
#org default 0x104
inserted at the start of your code (in front of the #use delay, and the RS232 definitions), to force these routines to all be located after the space you require.
The symbol map put main at 0x1b6c, though I think it's worth mentioning other functions I defined were put as low as 0x0004. Anyway, I put the following #org directive in:
#org 0x1b6c,0x1b6f {}
#ROM 0x1b6c = {1,2,3,4}
#org default
And the .hex file turned up the following:
00001B60  43 30 33 36 41 32 31 30 46 45 39 36 45 30 30 30  C036A210FE96E000
(That's from a listing I generated after commenting out #nolist in the device's header file.) It doesn't change if I comment out the #ROM directive.
Jeff S.
PostPosted: Tue Jul 13, 2004 7:15 am     Reply with quote
Have you found the problem yet?
I just stumbled across a similar case where I place a #device statement after the #org statement. Maybe this applies to your case as well?
The following code compiles without warning but makes the #org statement fail.
#include <18F458.h>
#device ICD=TRUE
#device adc=8        // This is the correct location for #device statements
#build(reset=0x0100)
#build(interrupt=0x0108)
// Reserve space for the bootloader
#org 0x000, 0x0FF
#rom 0x000 = {1, 2, 3, 4, 5, 6, 7, 8}   // Some test data
// #device adc=8      // This line makes the #org non-existant.
#use delay(clock=16000000)
The data in the region 0x00 - 0xFF is overwritten by the delay routine. I noticed this error when placing a function in the #org-ed region because the compiler then gave an error message.
PostPosted: Tue Jul 13, 2004 7:18 am     Reply with quote
I gave up and switched to storing persistent data in EEPROM. I couldn't devote any more time to figuring out the idiosyncracies of #org.
Jeff S.
Page 2 of 2
