Reading of const-array (2-dim) with PCH 3.202, Opt-9
UKH
PostPosted: Fri Jun 25, 2004 3:54 am     Reply with quote
Hello together,
during compiler-update (3.189 -> 3.202) one of a function creates
troubles:
byte const CAN_SPEED[4][5] =
// BRG, SYNC, PROP, PH1, PH2
{ 0, 0, 0, 3, 3}, // 1 MBit -> 30m (10 Tq)
{ 1, 0, 0, 3, 3}, // 500 kBit -> 100m (10 Tq)
{ 4, 0, 2, 5, 5}, // 125 kBit -> 500m (16 Tq)
{ 9, 0, 2, 5, 5} // 62,5 kBit -> 1000m (16 Tq)
void can_set_baud(byte b_nr) {
byte a;
b_nr = 0;
a =CAN_SPEED[b_nr][0]; // a=3 ? should be 0
a =CAN_SPEED[b_nr][1]; // a=1 ? should be 0
a =CAN_SPEED[b_nr][2]; // a=0 ? should be 0
a =CAN_SPEED[b_nr][3]; // a=0 ? should be 3
a =CAN_SPEED[b_nr][4]; // a=3 ? should be 3
b_nr=1;
a =CAN_SPEED[b_nr][0]; // a=3 ? should be 1
a =CAN_SPEED[b_nr][1]; // a=4 ? should be 0
a =CAN_SPEED[b_nr][3]; // a=2 ? should be 3
a =CAN_SPEED[b_nr][4]; // a=5 ? should be 3
b_nr=2;
a =CAN_SPEED[b_nr][0]; // a=5 ? should be 4
a =CAN_SPEED[b_nr][1]; // a=9 ? should be 0
a =CAN_SPEED[b_nr][2]; // a=0 ? should be 2
a =CAN_SPEED[b_nr][3]; // a=2 ? should be 5
a =CAN_SPEED[b_nr][4]; // a=5 ? should be 5
b_nr=3;
a =CAN_SPEED[b_nr][0]; // a=5 ? should be 9
a =CAN_SPEED[b_nr][1]; // a=f2 ? should be 0
a =CAN_SPEED[b_nr][2]; // a=cf ? should be 2
a =CAN_SPEED[b_nr][3]; // a=0e ? should be 5
a =CAN_SPEED[b_nr][4]; // a=f0 ? should be 5
The reading of the const-array doesn't works.
Has someone found the same ?
If I use OPT-8 (+Y=8) it works correctly ????
UKH
Haplo
PostPosted: Fri Jun 25, 2004 4:59 am     Reply with quote
Did the same code work correctly under 3.189?
If you look at the pattern of the data you are getting in the variable a, it is obvious that the compiler is skipping the first four bytes of your array and treating the fifth byte as the first. And that is also the reason why your last four readings are totally wrong.
UKH
PostPosted: Fri Jun 25, 2004 5:34 am     Reply with quote
Yes, same works with 3.189.
UKH
jventerprises
const array
PostPosted: Mon Jun 28, 2004 10:11 am     Reply with quote
i found that i could not use ICD and look at any values in the const array, but when i ran the code, it worked just fine. i could not step over the code that used the CONST, though.
i suspect it has to do with the compiler actually replacing these values at compile time, so they dont actually exist.
Jon
Haplo
PostPosted: Mon Jun 28, 2004 6:04 pm     Reply with quote
Yes, that is because the compiler implements a look-up table with RETLWs for constant arrays. It doesn't store the actual values in the memory.
UKH
PostPosted: Tue Jun 29, 2004 1:31 am     Reply with quote
Yesterday I've passed my problem to CCS. Currently I turned back to version 3.189 which works fine in this case.
UKH
Bug was confirmed by CCS
PostPosted: Wed Jun 30, 2004 11:58 pm     Reply with quote
Bug was confirmed and will be fixed in 3.203
UKH
