Is CCS able to manage long tables
joe06
PostPosted: Fri Mar 14, 2003 3:25 am     Reply with quote
Hi All,
Is this delaration allowed on a 16F877 ?
BYTE myvar[3][40];
this makes 3 tables of 40 Bytes, resulting in a 120 bytes table. on a 16F877, each RAM banks are 96 bytes length, is CCS able to split this table to the different RAM banks ?
thanks
joe
___________________________
Original Post ID: 12662
Re: Is CCS able to manage long tables
PostPosted: Fri Mar 14, 2003 12:51 pm     Reply with quote
:=Hi All,
:=Is this delaration allowed on a 16F877 ?
:=BYTE myvar[3][40];
:=this makes 3 tables of 40 Bytes, resulting in a 120 bytes table. on a 16F877, each RAM banks are 96 bytes length, is CCS able to split this table to the different RAM banks ?
CCS can not span ram banks with a large array.
Original Post ID: 12675
mark r. hahn
PostPosted: Fri Mar 14, 2003 6:01 pm     Reply with quote
:=Hi All,
:=thanks
:=joe
CCS can't handle this, but you can at the expense of some additional code. For example I had to have a 120 byte array for one project. I just split it into 2 60 byte arrays.
// in bank 0
byte array1[60];
// in bank 1
byte array2[60];
// use a function to access array
byte get_array_value(int index)
if (idx < 60)
return(array1[idx]);
return(array2[idx-60]);
Hey, I know it's sleazy. If you want better code, use one of the 18Fxxx parts, they have tons of RAM.
Mark
Original Post ID: 12693
joe06
PostPosted: Sat Mar 15, 2003 4:40 am     Reply with quote
ok thanks, I finally found a trick for that, creating 2 functions read_array and write_array, with both dimensions passed as parameters, and using #locate to place my splitted arrays in different banks.
joe
:=:=Hi All,
:=:=Is this delaration allowed on a 16F877 ?
:=:=BYTE myvar[3][40];
:=:=this makes 3 tables of 40 Bytes, resulting in a 120 bytes table. on a 16F877, each RAM banks are 96 bytes length, is CCS able to split this table to the different RAM banks ?
:=CCS can not span ram banks with a large array.
Original Post ID: 12705
