Receiving RS232 Data from PC using PIC18F4220
jpage
PostPosted: Thu Jun 24, 2004 10:06 am     Reply with quote
I am trying to test a very simple program that will receive a character ('?') and once it is received it will blink a Data LED a couple times.
If it is not the correct character, it will blink the the Power LED.
It is not working. Everytime I send a '?' character it, blinks the Power LED, which indicates that it is not the correct char.
I am using the built-in USART in the PIC.
I would appreciate any help. Thanks
Here is the code:
#include <18f4220.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT
#use delay (clock=20000000)
#use rs232(baud = 9600, parity=n, bits=8, xmit=pin_c6, rcv=pin_c7)
//defining LEDs
#define POWER    PIN_E2
#define DATA    PIN_D7
   //input character from VB or SIOW.exe from CCS//
   char data_in;
      //Power ON Indicator
      output_high(POWER);
      delay_ms(250);
      output_low(POWER);
      delay_ms(250);
      output_high(POWER);
      delay_ms(250);
      output_low(POWER);
      delay_ms(250);
   //endless loop
   //receive character from PC
   data_in = getc();
   //Checks received character
   if   (data_in == '?')
      //blink Data LED
      output_high(DATA);
      delay_ms(250);
      output_low(DATA);
      delay_ms(250);
      output_high(DATA);
      delay_ms(250);
      output_low(DATA);
      delay_ms(250);
      //if incorrect character, blink Power LED
   else{
      output_high(POWER);
      delay_ms(250);
      output_low(POWER);
      delay_ms(250);
      output_high(POWER);
      delay_ms(250);
      output_low(POWER);
      delay_ms(250);
PostPosted: Thu Jun 24, 2004 10:59 am     Reply with quote
There are a lot of obvious 'hardware' things that could cause this, but have to be checked.
Is the PC setup to use 9600bps?. On Hyperterm, you can sometimes get a situation that if you change the baud rate, it doesn't start using the 'new' rate, till the next time the package is used. How is the wiring done (what chip are you using to convert from RS232 levels to TTL?. Is your crystal 20MHz?. Is it possible that the oscillator has locked onto an 'overtone' (this sometimes happens if the crystal is overdriven, resulting in operation at an unexpected frequency...)?.
The behaviour is what you would expect if the baud rate was wrong at one end or the other (note that a lot of new PC's seem to have timing problems on their internal UART's - especially if the 'spread spectrum' option is enabled in the BIOS!...).
jpage
PostPosted: Thu Jun 24, 2004 11:21 am     Reply with quote
Thanks for the reply.
I have my PC setup exactly the same as the PIC as far as communications (9600, N, 8, 1).
I think I can rule out any problems with PC sending the correct baud rate because I just recently sent ASCII data to a different device that I am working on and that device was able to capture the data OK and it also worked at 9600 baud.
I have confirmed the PIC Xtal is operating at 20Mhz.
The RS232 to TTL conversion is done using a MAX323E.
I'm not absolutely convinced that it is not a hardware problem.
I would like to capture the converted TTL signal going into the PIC and verify that it is the correct ASCII char.
Any other suggestions would be welcome. Thanks.
Humberto
PostPosted: Thu Jun 24, 2004 11:54 am     Reply with quote
Hi jpage,
Just to know the char received, add a putc() function.
   //endless loop
   data_in = getc();
   putc(data_in);     //   ++++++++++ add this line ++++++++++++
   if   (data_in == '?')
      //blink Data LED
      output_high(DATA);
      delay_ms(250);
      output_low(DATA);
      delay_ms(250);
      output_high(DATA);
      delay_ms(250);
      output_low(DATA);
      delay_ms(250);
If you can borrow a scope, that will be the best way to "see" what´s going on.
Regards,
Humberto
jpage
PostPosted: Thu Jun 24, 2004 12:12 pm     Reply with quote
Thanks, I'll add the line and try it out.
I should be able to obtain a digital scope by tomorrow and look at the RS232 and TTL lines.
I'll keep you posted.
Thanks again.
Re: Receiving RS232 Data from PC using PIC18F4220
PostPosted: Thu Jun 24, 2004 2:39 pm     Reply with quote
Er. Hopefully you mean a MAX232, not a '323' (the latter is a solid state multiplexer).
Look forward to hearing how you get on with some 'trace' diagnostics using putc, and a scope.
jpage
PostPosted: Thu Jun 24, 2004 2:47 pm     Reply with quote
Uh oh..typo on my part.
I did mean MAX232.
Thanks.
