.HEX files with comments
future
PostPosted: Wed Jun 09, 2004 7:08 am     Reply with quote
By default, CCS includes a last line with ";processor name"
With that line, I am having problems with a bootloader not recognizing a valid structure.
Is there a way to prevent the compiler from doing this?
Radix
PostPosted: Wed Jun 09, 2004 7:29 am     Reply with quote
I don't know if it the processor id line can be turned off. Your bootloader should support the Intel hex file format.
The line before the processor line is of type 01, and indicates the end of the file.
:00000001FF
;PIC16C72A
Hint: Write an application in Delphi that removes the last line, if your bootloader has problems with it? Rolling Eyes
future
PostPosted: Wed Jun 09, 2004 8:03 am     Reply with quote
Even if I knew delphi it would be a lot of work, I prefer to edit manually and remove the line. Every time I compile a new code I would have to open the program or edit the file...
The bootloader comes from proton picbasic, it is very nice, has DTR/RTS cpu reset support, command line etc... I managed to work with a 18f452 40mhz.
No other bootloader I tried have these features.
Radix
PostPosted: Wed Jun 09, 2004 8:26 am     Reply with quote
Have you asked CCS?
future
PostPosted: Wed Jun 09, 2004 8:50 am     Reply with quote
Directly not, but do they read their forum? Very Happy
Kasper
PostPosted: Wed Jun 09, 2004 9:41 am     Reply with quote
I have the full source code for a simple Visual Basic boot loader ( works with CCS's loader.c)
http://www.ccsinfo.com/forum/viewtopic.php?t=19217
should be no problem to modify it to not send the last line.
Kasper
