CCS lcd drivers
asjad
CCS lcd drivers
PostPosted: Sun Jun 06, 2004 12:47 pm     Reply with quote
PCM 3.185
PIC16F874
Dear All,
Does anyone know if there is a conflict if I do the following:
USE timer 0 via interrupts AND
USE standard CCS lcd drivers.
I have tried to use them together and I think there is conflict somewhere
Does anyopne know what resources the CCS LCD drivers take up??
i.e any interrupts/timers
YOUR FEEDBACK IS ALWAYS APPRECIATED
Best Regards
PostPosted: Sun Jun 06, 2004 2:42 pm     Reply with quote
Does anyone know what resources the CCS LCD drivers take up??
To answer this type of question, just look at the driver file, LCD.C.
This file will be in this folder: c:\Program Files\Picc\Drivers
If you see any functions with #int_xxx in front of them, then
that's an interrupt routine. Once you look at LCD.C, you will
see the answer.
Konrad
Not all LCDs static
PostPosted: Mon Jun 07, 2004 2:41 pm     Reply with quote
Not all LCDs are static, that is the graphic LCDs have maximum clocking periods as well as minimum periods, so a timer interrupt could extend signals out of tollerance.
Try disabling the timer interupt before LCD functions, and re-enabling them afterwards.
