Program will only work in MPLAB simulator
Richard
PostPosted: Sun Jun 06, 2004 2:06 pm     Reply with quote
Dear PCM users,
I have recently bought the PCM compiler, I am having problem with the following code:
#if defined(__PCM__)
#include <16F874.h>
#device ICD=TRUE
#fuses XT,NOWDT,NOPROTECT,NOLVP,NOPUT,NOBROWNOUT
#include <lcd.c>
int sec=0; //second
int min=0;//minute
int hrs=0; //hour
int milli=0;
int increment = 0;
int flag=0;
int data=0;
void display()
      if (flag==1)
         lcd_gotoxy(0,1);
         printf(lcd_putc,"%02U:%02U",hrs,min);
         lcd_gotoxy(1,1);
         printf(lcd_putc,"%S",data);
#int_rtcc
void clock_isr()
    increment++;
   if (increment==2)
   {   milli++;
      increment=0;
   if (milli==10) // 10*100ms = 1second passed
      sec++;
      milli=0;
   if (sec==60) // 60*1sec = minute
       sec=0;
       min++;
       flag=1;
   if (min==60)
      min=0;
       hrs++;
      flag=1;
   if (hrs==24)
      sec=0;
      hrs=0;
      flag=1;
   if (milli < 10) //milli lower than 10 exit after incrementing milli
      set_RTCC(60); //setup TMR0 to count upto 100ms
    lcd_init();
   set_RTCC(60);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_256);
   enable_interrupts(INT_RTCC);
   while (1)
      if (flag==1)
         display();
         flag=0;
The code is for a rel time clock on the LCD (CCS LCD DRIVERS),
the interrupt happens every 49ms - using timer0
When I use MPLAB sim it works as it should, but if i blow it onto the chip I get nothing on the display.
I have tested the LCD, PIC, connectivity.
Can anyone program my code into a PIC or find any mistakes
I hope someone can help
Richard
PostPosted: Sun Jun 06, 2004 2:08 pm     Reply with quote
PCM 3.185
I am using the MPLAB ICD2 - MPLAB 6.3
NO COMPILER ERRORS!!!
PostPosted: Sun Jun 06, 2004 2:39 pm     Reply with quote
I tested it with PCM vs. 3.188. I changed the printf statements
to send output directly to the PC terminal window, because I don't
have a LCD on my demo board.
I also added one line to your int_rtcc function, so that it would
display output every second, instead of every minute.
That's better for a test program.
Then it worked. It displayed this every second:
00:00
sec++;
milli=0;
flag = 1; // Add this line to get output every 1 second.
Richard
THANKS
PostPosted: Sun Jun 06, 2004 3:06 pm     Reply with quote
I have been trying to get this working for the past week
You are truely a PCM programmer
Thank you!!!
