loop through all a/d channels
future
PostPosted: Sat Jun 05, 2004 4:55 pm     Reply with quote
Can someone give me a hint on how to read all channels without using interrupts?
Every time the loop runs one channel is read, if adc is busy then it skips.
I would like to use it in main loop, so it does not interrupt the code just to copy the results to adc_array[8].
Neutone
PostPosted: Sat Jun 05, 2004 5:49 pm     Reply with quote
I did something like this once. I thought it was more effective to read, average and select channel once per pass. I did it with if statements because I think its a faster method than using case select statements.
http://home.houston.rr.com/neutone/analog.c
