Is there a way to return two values from a function?
future
PostPosted: Wed May 26, 2004 5:37 pm     Reply with quote
I wan't to write a function that receives two values and returns 2 values.
It is a table lookup routine that finds the bin position and fetch the value from 2 tables.
PostPosted: Wed May 26, 2004 5:43 pm     Reply with quote
I want to write a function that receives two values and returns 2 values.
See the demo program at the end of this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=18265
valemike
PostPosted: Wed May 26, 2004 8:41 pm     Reply with quote
Yup, PCMPr. is correct. If you want to return two ints, you'll need to create a struct with at least two of those ints, and return the name of the struct, which is the same as returning a pointer to that struct.
Darren Rook
PostPosted: Thu May 27, 2004 8:09 am     Reply with quote
Or you can use pointers as a parameter in the function. Many times this is more effecient than passing and returning structures.
