int_rda during sleep?
ben_r
PostPosted: Thu May 27, 2004 7:42 am     Reply with quote
Is it possible for int_rda to work when the PIC is sleeping - im a bit confused by reading the data sheet (18F2320).
What I want to do is to sleep until a byte is recevied, then wake and process it - but at the moment the PIC just sleeps forever (int_rda & int_global are enabled).
Im using a 10Mhz XTAL with the x4 PLL and the UART is running at 115.2KBaud (the UART works fine - untill it sleeps).
Gerrit
PostPosted: Thu May 27, 2004 7:53 am     Reply with quote
Hi Ben_r,
When putting the microchip to sleep disables the uart as well from
functioning.
And you can't wakeup after detecting a start bit (via external int)
Takes to long to start.
Regards,
Gerrit
