Built- in functions and int
.C
PostPosted: Sat May 22, 2004 8:52 am     Reply with quote
Do you know if interrupt handler break any built functions?
Thank
Humberto
PostPosted: Sat May 22, 2004 2:08 pm     Reply with quote
Not exactly "break", but interrupt it. (If such interrupt was enabled)
The interrupt handler is the code related to the corresponding hardware
vector interrupt. By itīs nature, itīs "triggered by the hardware" so it has
higher priority than the rest of the code, like a built in function.
HTH,
Humberto
.C
PostPosted: Sat May 22, 2004 2:48 pm     Reply with quote
future
PostPosted: Sat May 22, 2004 5:02 pm     Reply with quote
Does it have problems if the interrupt handler modifies data that were used in the code that was running? or it has a protection to this not happen?
Neutone
PostPosted: Sun May 23, 2004 9:13 am     Reply with quote
This can be a problem. For example when incrementing a 16 bit number and the lower byte rolls over the upper byte should be incremented. If in interupt occurs between these two operations you could have the sort of problem you discribe. The compiler can not protect aginst this. This requires carefull coding.
