Receiving and Transmitting over RS232 using interupts
jamesjl
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
PostPosted: Thu May 13, 2004 1:11 pm     Reply with quote
Hi All,
I am using the standard C commands from the CCS complier to hand my RS232 comms. I am using an RDA_ISR routine to handle incoming bytes and just a standard fputc(data) command to send it. Is there a better way? I see that some example here directly access the registers to perform the transmissions and receptions. Is this a more efficient way? How much more complicated is it? Is the effort required rewarded in an improvement in performance?
Any suggestions to pointers to sources of existing code would be greatly appreciated.
Thanks,
Jason.
PostPosted: Thu May 13, 2004 1:20 pm     Reply with quote
Look at the CCS example files, EX_SISR.C and EX_STISR.C.
You can find these files here: c:\Program Files\Picc\Examples
PostPosted: Fri May 14, 2004 1:33 am     Reply with quote
If your processor has an internal hardware UART, than the method you describe is efficient and only a few bytes of ROM can be saved by direct port access. The other examples you have seen probably have added functionality like RTS/CTS flow control, or even more likely are examples of doing serial commnications without a hardware UART.
