16F or 16LF ?
Lorenzo
16F or 16LF ?
PostPosted: Tue Apr 13, 2004 2:42 am     Reply with quote
May I use a PIC16F648A with a 3Vą3% power supply (this PIC works
with a 3.0V<VDD<5.5V), or it's necessary a 16LF648A ?
Best regards.
Lorenzo
Haplo
PostPosted: Tue Apr 13, 2004 3:53 am     Reply with quote
According to the datasheet, PIC16F648A has wide operating voltage range (2.0v-5.5v). So 3v should be ok.
http://www.microchip.com/download/lit/pline/picmicro/families/16f6xx/40044b.pdf
Pete Smith
View user's profile Send private message Visit poster's website MSN Messenger ICQ Number
PostPosted: Tue Apr 13, 2004 4:46 am     Reply with quote
Be careful here. I've not read this data sheet, but IME, the 16F87X and the 16F84 data sheets also say they run between 2.0 and 5.5, but when you actually get down to it, only the 16LF parts will run at this voltage, but it's not obvious when looking at the documentation, unless you look at the graphs in the back.
Pete.
Haplo
PostPosted: Tue Apr 13, 2004 5:23 am     Reply with quote
Yes Pete is right, my mistake. It might be a better idea to use the LF part.
Pete Smith
PostPosted: Thu Apr 15, 2004 4:41 am     Reply with quote
This one really bit us on the arse. We made a short run of devices, which all seemed to work fine.
We then made lots more, and found about 10% of them didn't work. This being we were using F parts and were running them at 3v.
We then had to remove all the PICs, buy new ones in (LF part), and then re-program and re-attach the PICs.
Great fun!
Pete.
Haplo
PostPosted: Thu Apr 15, 2004 6:48 am     Reply with quote
The datasheet is mostly to blame. The only thing it mentions is that the device is a wide-range part, from 2.0v to 5.5v. And only the graphs towards the end show that for operating at very low voltages you need the LF part.
A better datasheet structure might have saved you all the fun, Pete.
Pete Smith
PostPosted: Fri Apr 16, 2004 3:06 pm     Reply with quote
Don't I know it! Smile
It was my own fault for not checking the datasheet thoroughly enough.
Pete.
