PCB -entering new components
asjad
PostPosted: Sun Apr 11, 2004 9:57 am     Reply with quote
CAD package - EDWIN
Dear All,
Does anyone have any experience in creating new components
in a PCB package.
I am familiar on how to enter information into the package.
Do you simply measure the diemensions with a bog standard ruler??
I am using a ruler with millimeters, but standard compoenents can be
2.54mm (0.1")???
Any advice, tips??
Best Regards
Neutone
PostPosted: Sun Apr 11, 2004 10:55 am     Reply with quote
The data sheet usually specifies the dimentions. Also many vendors have datasheets showing how to layout pads.
Steph
PostPosted: Sun Apr 11, 2004 4:22 pm     Reply with quote
Normally, the footprint standard is in millimeter.
But the real footprint standard name is JEDEC.
look at the end of the pattern name like MCP41010SN
soic 8, that is soic-8 narrow body (150mils).
JEDEC equivalent is MS-012.
Look at different name I found for soic 8 (150 mils) body.
JEDEC SO-8 MS-012.
-SO-8
-SOIC-8
-SO-8 NARROW
-SOIC-8 NARROW
-SO-8 (150mils)
and for so-8 (300 mils)
JEDEC SO-8 MS-013
-SO-8
-SOIC-8
-SO-8 WIDE
-SOIC-8 WIDE
SO-8 (300mils)
the jedec MS-012 must be 150 mils body for each company.
Each time you meet the JEDEC name it should be
the standard for all company pattern name.
When you create a footprint that is very important
to add the JEDEC name:
ex: SO-8 (MS-012)
To create a footprint you can use ipc standard:
http://landpatterns.ipc.org/default.asp
SherpaDoug
Clarification
PostPosted: Mon Apr 12, 2004 11:34 am     Reply with quote
Note that 1 mil = .001 inch. Most package dimensions are based in inches.
Steph
PostPosted: Mon Apr 12, 2004 5:21 pm     Reply with quote
TAKE CARE, if you do not have a millimeter on
package dimension.
That is not true footprint are base on millimeter.
If you try to make BGA or flat pack in mils,
you would be on trouble.
