ADF4351 Frequency Generator Code
Post new topic   Reply to topic    CCS Forum Index -> Code Library
patan_mustafa
PostPosted: Sun Feb 09, 2025 12:54 am     Reply with quote
I write this code to bring up my ADF4351 setup with PIC16F1933. You can check your circuit with a fm radio while setting frequency between 88.0MHz-108.0MHz if you do not have an oscilloscope. You must hear a blank audio your at frequency setting. I connect adf output with a 1Mohm resistor to radio antenna
#define ADF_CE    PIN_C3
#define ADF_LE    PIN_C4
#define ADF_DATA  PIN_C5
#define ADF_CLK   PIN_C6
#define ADF_MUX   PIN_C7
void write_to_adf4351(int32 a){
signed int i;
   output_low(ADF_LE);  for(i=31;i>=0;i--){  output_low(ADF_CLK);   output_bit(ADF_DATA, bit_test(a,i));  delay_ms(1);   output_high(ADF_CLK);  }   output_high(ADF_LE);
int divider=0;
int16 mod=10,keypad_value;
int32 intmask    =0b01111111111111111000000000000000, intmasknot =0b10000000000000000111111111111111;
int32 fracmask   =0b00000000000000000111111111111000, fracmasknot=0b11111111111111111000000000000111;
int32 frequency=35000, ref_in=10000, kademe,integer=0,frac=0;
int32 reg[6]={0x00700000,0x08000151,0x00004EC2,0x000004B3,0x00C5003C,0x00C00005};
float fstep=0;
// FREQUENCY value for 35.0MHZ is frequency=35000 @10MHz Ref in
void set_freq(void){
   if(frequency>=10000 && frequency<=4400000){
         if(      frequency >=  10000 && frequency <=  17500){ divider=64; bit_set(  reg[4],22); bit_set(  reg[4],21); bit_clear(reg[4],20); mod=156; frequency=frequency*4; }
         else if( frequency >   17500 && frequency <   34375){ divider=32; bit_set(  reg[4],22); bit_clear(reg[4],21); bit_set(  reg[4],20); mod=312; frequency=frequency*4; }
         else if( frequency >=  34375 && frequency <=  70000){ divider=64; bit_set(  reg[4],22); bit_set(  reg[4],21); bit_clear(reg[4],20); mod=156; }
         else if( frequency >   68750 && frequency <= 140000){ divider=32; bit_set(  reg[4],22); bit_clear(reg[4],21); bit_set(  reg[4],20); mod=312; }
         else if( frequency >  137500 && frequency <= 275000){ divider=16; bit_set(  reg[4],22); bit_clear(reg[4],21); bit_clear(reg[4],20); mod=625; }
         else if( frequency >  275000 && frequency <= 550000){ divider=8;  bit_clear(reg[4],22); bit_set(  reg[4],21); bit_set(  reg[4],20); mod=1250;}
         else if( frequency >  550000 && frequency < 1100000){ divider=4;  bit_clear(reg[4],22); bit_set(  reg[4],21); bit_clear(reg[4],20); mod=2500;}
         else if( frequency >=1100000 && frequency < 2200000){ divider=2;  bit_clear(reg[4],22); bit_clear(reg[4],21); bit_set(  reg[4],20); mod=4095;}
         else if( frequency >=2200000 && frequency < 4400000){ divider=1;  bit_clear(reg[4],22); bit_clear(reg[4],21); bit_clear(reg[4],20); mod=10;}
         fstep=(float)ref_in/divider;
         integer=(int32)frequency/fstep;
         frac=frequency-(integer*fstep);
         integer=(integer<< 15); integer=(integer)&intmask;  reg[0]=(reg[0])&intmasknot;  reg[0]=(integer)|reg[0];
         frac   =(frac   << 3 ); frac   =(frac   )&fracmask; reg[0]=(reg[0])&fracmasknot; reg[0]=(frac   )|reg[0];
         mod    =(mod    << 3 ); mod    =(mod    )&fracmask; reg[1]=(reg[1])&fracmasknot; reg[1]=(mod    )|reg[1];
         write_to_adf4351(reg[5]); delay_ms(1);
         write_to_adf4351(reg[4]); delay_ms(1);
         write_to_adf4351(reg[3]); delay_ms(1);
         write_to_adf4351(reg[2]); delay_ms(1);
         write_to_adf4351(reg[1]); delay_ms(1);
         write_to_adf4351(reg[0]); delay_ms(3);
djsb
PostPosted: Thu Nov 19, 2026 1:54 pm     Reply with quote
Where is the rest of the code? And it would be nice if the cost was commented.
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
